1934 Ford 3-Window real steel Coupe (Late "33 Manufacture Body and chassis) Ford 289 HiPo 4spd - Original 1933 Henry Ford Steel Body, Original 1934 Hood, Original 1934 Hood Sides, Original "33 Inner Fenders. Complete Pete & Jakes Chromed-out Front and Rear Suspension. This is a genuine and rare three window, it s the real deal and correctly registered.<br />
<br />
This body is a rust-free example...solid!!!<br />
<br />
Original Seat Frame and pan!!!<br />
<br />
Original 1933 Henry Ford Chassis - Boxed (The Chassis and Body are the Matched Original Henry Ford Manufacture & Serial Numbers)<br />
<br />
This is a VERY High-End no expense spared all ford build!!!<br />
<br />
Ford 1967 Ford GT-350 289CI HiPo motor Completely Rebuilt<br />
<br />
Ford 1967 Ford GT -350 9 Nodular rear Axle- completely rebuilt<br />
<br />
BRAND NEW RICHMOND T-10 4SPEED TRANSMISSION<br />
<br />
4.10 Rear Gears & Detroit Locker Posi unit Brand New (33" tall tires - effective 3.70 ratio)<br />
<br />
Ford Aluminium Tri-power - Holley Carbs - Progressive Linkage (All Brand New)<br />
<br />
ATI SFI Harmonic Balancer - External Balancer<br />
<br />
Remote Polished Spin-on Oil Filter w/SS Teflon lines covered in rubber lines (old school look w/modern safety)<br />
<br />
So-Cal Polished T-6 Aluminium Engine Mounts<br />
<br />
Polished Aluminium Finned Oil Pan, Rocker Covers, Alternator Mount, Moon Breathers, lots of Polished & Cast parts!!!<br />
<br />
Pete & Jakes Narrowed Super Slide Rear Spring<br />
<br />
Wheel Vintiques 16" custom Jenny Wheels - SS Trim Rings and Caps - Brand new<br />
<br />
Coker Firestone Rear Tires - 890-16 Grooved Rear "Dirt Track" ($880.00) - Brand New<br />
<br />
Coker Firestone Front Tires 550-16 Bias Ply - Brand New<br />
<br />
Custom Aluminium Drive Shaft - balanced<br />
<br />
Chromed-out Ford F1 Steering Box<br />
<br />
So-Cal Polished USA Rod Ends<br />
<br />
LimeWorks "40 Ford steering column<br />
<br />
Moroso Mechanical Tach and Aluminium Pod<br />
<br />
Original 1933 Ford Dash and Gauges NOS - Pristine<br />
<br />
SW Green Line 2 5/8" Early Mechanical Gauges (Oil Pressure/Water Temperature)<br />
<br />
SW Green Line 2 5/8" Gas Gauge (New)<br />
<br />
Tilton Hydraulic throw-out bearing<br />
<br />
Hurst Performance Shifter<br />
<br />
SFI Quick-time Bellhousing, SFI Flywheel, SFI Clutch & SFI Pressure Plate<br />
<br />
Powermaster 9453 - Powermaster Ultra Torque High Speed Starters<br />
<br />
Vertex Magneto - completely new inside w/correct curves (Pat Mason Racing) ($1200.00)<br />
<br />
Stainless Steel 2.5" Exhaust System<br />
<br />
Stainless Steel Gas Tank<br />
<br />
Top of the line SS Teflon Gas Lines (Aeroquip)!!!<br />
<br />
Pete & Jakes Front/Rear Chrome Nerf Bars<br />
<br />
Pete & Jakes Chrome Ladder Bars (Long)<br />
<br />
Original Chromed-out Buick Aluminium 45 fin Drum brakes<br />
<br />
Original Chromed-out Front early Ford Drum Backing plates with SS Aero Vents (Very expensive)<br />
<br />
Griffin 4-core Aluminium "34 Radiator (Mechanical & Electric Fan) (Electric for parades)<br />
<br />
1934 Commercial Headlights with Turn Signals - SS Stands/Mounts<br />
<br />
Vintage Air Hot Rod Heater - Electric Wind Shield Wiper<br />
<br />
Ron Francis complete Wiring Harness - RF Automatic 2-speed fan control set at 185* & 195*<br />
<br />
California Cover - Flannel Lined - (New $439.00)<br />
<br />
Rear Window fully functional, including swing-out windshield<br />
<br />
**Note** Complete brand new LeBarron Bonney Interior Kit not installed comes with the Car ($3000.00) Matches the new LB Seat Covers<br />
<br />
LeBarron Bonney "34 Ford upholstered Sun Visors (New $350.00)<br />
<br />
Runs, Drives & Sounds FANTASTIC...This Awesome Rod has been built with top end parts and no expense spared.<br />
<br />
You can run it is in its period style or for a show perfect top end rod paint it and some small TLC in a couple of spots this is the perfect start.<br />
<br />
You won"t be disappointed with your purchase!!! If you know your rods you will know a chance to own an original steel window is rare in its self and with the ever-changing rules of import, the chance to own an authentic hotrod in Europe will be a rarer opportunity.<br />
<br />
The only reason I am selling is so I will be able to buy something else that has become available... <br />
Date written: 14-Nov-2017
Price: £50000 As stated
