This 1970 Plymouth Cuda is flat out fantastic! The exterior is show quality with a laser-straight metal body dressed in glossy factory specified Tor-Red paint. The underside looks factory new and is as correct as you can get. The numbers matching powertrain starts with the potent 340CID 4BBL 275HP V8 engine which pushes all the power through the “Slapstick? torque-flight automatic transmission all the way to the 4.10:10 Dana limited slip rear axle. All the mechanics are not just in working o...
More...
