Best breathalysers
K
Kim Adams
After a night out, most of us will arrange transport, but when will you be safe to drive again? Research shows too, that more of us are enjoying a drink at home. The message is clear: if you drink, don’t drive. But the best way to ensure you’re fit for the road the morning after is with a home breathalyser,
Home breathalysers are designed to help ensure you’re under the legal drink-drive limit when you take the wheel the morning after a night of drinking and celebrating. There’s a wide choice, between basic semi-conductor devices and sophisticated fuel-cell products, costing from a few quid to over £100. So which of our selection of readily available products best protects you and your licence?
How we tested them​
Accuracy is key, as your licence is on the line if a unit reads low, and the device is not doing its job if it is consistently high. We did five tests using certified samples at the limits for Scotland (0.22mg of alcohol in one litre of breath) and England and Wales (0.35mg/l).
Sensitivity was rated at a low 0.09mg/l level, plus we looked at how units recover after a high alcohol sample (0.6mg/l) by taking alternate readings between the two.
Solutions were checked against a police-spec Draeger breathalyser after each set of tests. Ease of use, instructions, alerts and cost using makers’ or online prices were all rated.
There’s no doubt you get what you pay for with these breathalyser kits. AlcoSense has the edge here, with the choice down to your budget. The Excel provides a great combination of price and performance, while the Elite 3 looks great at the price. For the next step up, look no further than the Pro. Our pick of the AlcoDigital units, the Platinum, is the best of rival products.
  1. AlcoSense Excel
  2. AlcoSense Elite 3
  3. AlcoSense Pro
Reviews​
AlcoSense Excel​
AlcoDigital AL7000
5. AlcoDigital AL7000Price: £79.95 Contact: www.alcodigital.co.ukRating: 3 stars
OFTEN Breath Alcohol Tester
9. OFTEN Breath Alcohol TesterPrice: £13.99Contact: www.amazon.co.ukRating: Not rated
AlcoSense Elite
4. AlcoSense ElitePrice: £59.99 Contact: www.alcosense.co.ukRating: 4 stars
AlcoSense Pro
2. AlcoSense ProPrice: £149.99 Contact: www.alcosense.co.ukRating: 4 stars
AlcoDigital Platinum
3. AlcoDigital PlatinumPrice: £149.95 Contact: www.alcodigital.co.ukRating: 4 stars
ALC Nose Breathalyzer Compact Party Tester
10. ALC Nose Breathalyzer Compact Party TesterPrice: £19.99Contact: www.ebay.co.ukRating: Not rated
AlcoSense Excel
1. AlcoSense ExcelPrice: £99.99 Contact: www.alcosense.co.ukRating: 5 stars
AlcoSense Elite 3
AlcoSense Elite 3
Kaisimys AD-6000NS
Kaisimys AD-6000NS
AlcoDigital Platinum Lite
6. AlcoDigital Platinum LitePrice: £99.95 Contact: www.alcodigital.co.ukRating: 3 stars
Best breathalysers - header
We test 10 breathalysers to see which is the best.
VicTsing Mini Digital Keychain Alcohol Tester
8. VicTsing Mini Digital Keychain Alcohol TesterPrice: £11.99 Contact: www.amazon.co.ukRating: 1 star
Alcoscan ACE AL2600
7. Alcoscan ACE AL2600Price: £27.54 Contact: www.amazon.co.ukRating: 1 star
ACE AL5500 plus
ACE AL5500 plus
Like the more expensive AlcoSense product, this brand new fuel-cell device is a breeze to use. It has the same high-quality casing and the display is a step above the rest, plus it’s easily seen while blowing.
Alcohol limits for different countries can be set and instructions are comprehensive, plus they explain why the read-out is set 20 per cent high to comply with European standards and potential under-reading over time.
Using factory settings to access the true reading, it proved accurate at all levels. A great blend of price and performance.
Buy it on Amazon
AlcoSense Elite 3​
AlcoDigital AL7000
AlcoSense Elite
AlcoSense Pro
AlcoSense Excel
AlcoSense Elite 3
AlcoSense Elite 3
Kaisimys AD-6000NS
Kaisimys AD-6000NS
Alcoscan ACE AL2600
ACE AL5500 plus
ACE AL5500 plus
This is AlcoSense’s top semi-conductor breathalyser, and sits just under the more accurate (and pricier) fuel-cell models. The Elite 3 can’t quite match a fuel cell for accuracy, but it was consistent and read a little high. AlcoSense says this allows for the drop in results over time before recalibration is required.
As we've seen with their other models, it wasn’t lab performance that set the AlcoSense apart, but the overall package. The Elite can be adjusted for the blood/breath ratio and unit of measurement, while limits are listed for the UK and Ireland, including the latter’s professional and learner levels. There’s a traffic-light system for results, with a 20 per cent margin if you are close to the red limit. A good alternative to expensive fuel-cell breathalysers.
Buy now from AlcoSense
AlcoSense Pro​
AlcoDigital AL7000
AlcoSense Elite
AlcoSense Pro
AlcoSense Excel
AlcoSense Elite 3
AlcoSense Elite 3
Kaisimys AD-6000NS
Kaisimys AD-6000NS
Alcoscan ACE AL2600
ACE AL5500 plus
ACE AL5500 plus
Spend £50 more than on the AlcoSense Excel, and you get quite a bit extra with this Pro model. It’s another fuel-cell breathalyser, and like its stablemate it has a lead to update firmware via USB, and clear colour-coded alerts to warn you not to drive within 20 per cent of the set limit.
But the Pro adds a Blow Coach to ensure the breath sample will provide the most accurate reading, plus it gives an estimate of when you’re likely to be under the limit. You can also set a reminder alarm to take a retest. It topped our accuracy tests by a small margin from the Excel.
Buy it on Amazon
AlcoDigital Platinum​
AlcoDigital AL7000
AlcoSense Elite
AlcoSense Pro
AlcoSense Excel
AlcoSense Elite 3
AlcoSense Elite 3
Kaisimys AD-6000NS
Kaisimys AD-6000NS
Alcoscan ACE AL2600
ACE AL5500 plus
ACE AL5500 plus
Whether a breathalyser uses the more accurate fuel cell or a semi-conductor to measure alcohol on the breath, it needs to be recalibrated regularly. Most makers recommend this is done at least once a year, but with this AlcoDigital Platinum the fuel-cell cartridge sensor can be changed by the user – handy if you can’t afford to be without your device.
As our emphasis was on accuracy, it was no surprise that this fuel-cell unit completed the podium. It’s accurate, but the AlcoDigital can’t be set to different drink-drive limits – although the UK figures are clearly spelled out in the instructions.
Buy it on Amazon
ACE AL5500 plus​
AlcoDigital AL7000
AlcoSense Elite
AlcoSense Pro
AlcoSense Excel
AlcoSense Elite 3
AlcoSense Elite 3
Kaisimys AD-6000NS
Kaisimys AD-6000NS
Alcoscan ACE AL2600
ACE AL5500 plus
ACE AL5500 plus
This German device just had the edge on accuracy over our pick here, because it got closest to our certified sample levels. In fact it was a little too close, since it marginally under-read across the multiple readings, which leaves little margin for error as the semi-conductor’s accuracy drops over time. It dealt well with the high and low assessment, but there’s no adjustment for different countries and you need to know the limits where you plan to drive.
Buy it on Amazon
AlcoDigital AL7000​
AlcoDigital AL7000
AlcoSense Elite
AlcoSense Pro
AlcoSense Excel
AlcoSense Elite 3
AlcoSense Elite 3
Kaisimys AD-6000NS
Kaisimys AD-6000NS
Alcoscan ACE AL2600
ACE AL5500 plus
ACE AL5500 plus
Another AlcoDigital unit that allows users to change the breath alcohol sensor, but this is a semi-conductor.The AL7000 is supplied with a hard case and a car adaptor charge lead. This is handy, but you can’t set different drink-drive limits. However, once again the instructions make them clear for the UK and France.
It proved reasonably accurate during our test, but there are more reliable devices here at this price.
Buy it on Amazon
AlcoDigital Platinum Lite​
AlcoDigital AL7000
AlcoSense Elite
AlcoSense Pro
AlcoSense Excel
AlcoSense Elite 3
AlcoSense Elite 3
Kaisimys AD-6000NS
Kaisimys AD-6000NS
Alcoscan ACE AL2600
ACE AL5500 plus
ACE AL5500 plus
This is another fuel-cell device, but this time it can’t be changed by the user and needs to be sent away for recalibration, like most units on test.
As with the pricier Platinum model, this has an integrated mouthpiece that slides out from the top of the casing.
It proved reasonably accurate, but there were more consistent devices – and that hurt its overall chances. Plus, we would have liked to have been able to set the relevant drink-drive limit.
Buy it on Amazon
Kaisimys AD-6000NS​
AlcoDigital AL7000
AlcoSense Elite
AlcoSense Pro
AlcoSense Excel
AlcoSense Elite 3
AlcoSense Elite 3
Kaisimys AD-6000NS
Kaisimys AD-6000NS
Alcoscan ACE AL2600
ACE AL5500 plus
ACE AL5500 plus
When gathering samples, we looked for semi-conductor devices around the price of the new Elite 3. This Kaisimys was £84.99 when bought, but had vanished from Amazon by the time it was tested and lookalikes were a quarter of that figure. Whatever the cost, it’s a device to avoid. It arrived with failed elements in the LED screen, making reading tricky, and some of its results were worryingly low before it gave up in the high-low test. Not worth your money at any price.
Alcoscan ACE AL2600​
AlcoDigital AL7000
AlcoSense Elite
AlcoSense Pro
AlcoSense Excel
AlcoSense Elite 3
AlcoSense Elite 3
Kaisimys AD-6000NS
Kaisimys AD-6000NS
Alcoscan ACE AL2600
ACE AL5500 plus
ACE AL5500 plus
The best of the budget online devices, although that’s no reason to buy this. It was one of two products on test not to use a mouthpiece, which creates potential for a variable breath sample depending on where the unit is held. Across the two legal limits it was way off the desired readings. Its saving grace was that it consistently read high.
There are no legal limits mentioned in the instructions – which incidentally are really poorly translated – and the display is difficult to read in the dark.
Buy it on ebay
VicTsing Mini Digital Keychain Alcohol Tester​
AlcoDigital AL7000
AlcoSense Elite
AlcoSense Pro
AlcoSense Excel
AlcoSense Elite 3
AlcoSense Elite 3
Kaisimys AD-6000NS
Kaisimys AD-6000NS
Alcoscan ACE AL2600
ACE AL5500 plus
ACE AL5500 plus
Given the variations in the way the body absorbs alcohol, these devices are primarily aimed at morning after use, so we’d question the wisdom of having a breathalyser on your key ring.
And looking at the test results, we’re not sure this is a sensible buy at all. It was significantly out at the legal limits – although, like the Alcoscan, it read high. Uniquely it said users should rinse their mouths with water before testing, which risks affecting the sensor with moisture.
Buy it on Amazon
OFTEN Breath Alcohol Tester​
AlcoDigital AL7000
AlcoSense Elite
AlcoSense Pro
AlcoSense Excel
AlcoSense Elite 3
AlcoSense Elite 3
Kaisimys AD-6000NS
Kaisimys AD-6000NS
Alcoscan ACE AL2600
ACE AL5500 plus
ACE AL5500 plus
Amazon’s listing claims this is a ‘police digital breath alcohol tester’. It looked nothing like our £7,500 control unit, and performed nothing like it, either.
Its gloss black finish and bright display mask one of the worst devices on test, as unlike other budget units its readings varied wildly. At the England and Wales limit it gave a reading either side. It was high at the Scottish and low levels, and in the strong alcohol test it locked out after our first attempt. This makes you question the four-star rating Amazon users give it.
Buy it from Amazon
ALC Nose Breathalyzer Compact Party Tester​
AlcoDigital AL7000
AlcoSense Elite
AlcoSense Pro
AlcoSense Excel
AlcoSense Elite 3
AlcoSense Elite 3
Kaisimys AD-6000NS
Kaisimys AD-6000NS
Alcoscan ACE AL2600
ACE AL5500 plus
ACE AL5500 plus
Getting a result was a lottery as this Alc Nose unit has no mouthpiece. Even when we found a spot for it to take a reading, it failed to take one the next time we tried from the same position.
We could see where the intake was, which would not be the case if you were blowing into it – when we got a reading it was way off where it should have been. No limits are mentioned and the display includes a misleading wine glass graphic. Best thing about this breathalyser is the batteries; they worked but the unit didn’t.
Buy it on Amazon
T
Tom Barnard
T
J
James Stanbury
J
D
Dave Pollard
D
D
Dave Pollard
D
D
Dave Pollard
D
