Best LED work lights and inspection lamps 2021
K
Kim Adams
NO matter how well lit your workshop is, or how bright the day, at some point you will need more light when you’re working on cars. Fortunately getting light where you want it has never been easier, because advances in LED and battery technology have seen the output of inspection lamps increase, and run times lengthen.
Cordless is the way to go, with the best lasting well over two hours, and no leads trailing across the floor or drive to trip over. Makers have also exploited the new tech to come up with innovative designs that make it easier than ever to put light where it’s needed. So which of the latest designs is the shining star? We charged eight to find out.
How we tested them​
As designs have improved and converged, we have refined our test to find a worthy winner. We measured light output and beam spread, as well as assessing torches and the run time at maximum power. We also looked for power-saving modes, plus battery-charge and state indicators before heading under a wheelarch and bonnet for practical tests to see how easy it is to get light where it’s needed. The final factor was the price, which we obtained from online sources.
Ring’s MAGflex Slim narrowly beats the Sealey SlimFlex at its own game with a small yet versatile blade light.
  1. Ring MAGflex RIL3900HP
  2. Sealey LED1801
Reviews​
Ring MAGflex RIL3900HP​
NightSearcher Pocket Pro
Draper 11767
Draper 11767
Sealey LED1801
Sealey LED1801
Laser 7056
Laser 7056
Draper 90187
Draper 90187
NightSearcher Tri-Spector
LED worklights and inspection lamps header
Philips RCH25
Philips RCH25
Clarke RWL-55
Clarke RWL-55
When you see how similar the MAGflex Pivot is to the Sealey it’s no surprise the two were closely matched, but the Ring just edges out the former winner here. The Ring is a smaller package, some three centimetres or so shorter when folded, but the COB (chip on board) strip still manages to push out 400 lumens. With a similar 2.6Ah Li-ion battery, it had the edge in the run time test, at almost four hours. Add in its keen price, a thumbwheel dimmer, plus charge and battery state indicator, and you have a winner.
Buy now from Amazon
Sealey LED1801​
Draper 11767
Draper 11767
Sealey LED1801
Sealey LED1801
Laser 7056
Laser 7056
Draper 90187
Draper 90187
Philips RCH25
Philips RCH25
Clarke RWL-55
Clarke RWL-55
The LED180 was top in our last multi-test two years ago and now Sealey has boosted the power and output of the SlimFlex design, with the 12 SMD (surface mount device) LEDs punching out 500 lumens – up from 400. Yet it wasn’t quite enough to hang on to the crown. Its beam had the edge on the Ring’s, and the light had the same easily directed twist-and-fold blade. But it shut down after two and half hours in the run-time test and had neither a battery-state indicator nor, crucially, a mains adaptor for the USB charging lead.
Buy now from Sealey
NightSearcher Pocket Pro​
Draper 11767
Draper 11767
Sealey LED1801
Sealey LED1801
Laser 7056
Laser 7056
Draper 90187
Draper 90187
Philips RCH25
Philips RCH25
Clarke RWL-55
Clarke RWL-55
One look tells you NightSearcher is bucking the trend for work lights with the Pocket Pro, and this can also be seen by the inclusion of a mains adaptor for the USB charge lead. Most rivals just supply a cable. The Pocket Pro punches out 600 lumens, giving it a clear advantage over the Ring’s 400, but its beam was narrower. It had a similar advantage with its torch.
Less good were the single-LED charge and battery state indicator, and just two power modes. It also ducked out 60 or so minutes before its rival, although it still lasted close to three hours in the run-time test. Getting light where needed via the hinged magnetic base is not as easy as it is with the Ring offering, but if output is key then this is the one to go for.
Buy now from NightSearcher
Philips RCH25​
Draper 11767
Draper 11767
Sealey LED1801
Sealey LED1801
Laser 7056
Laser 7056
Draper 90187
Draper 90187
Philips RCH25
Philips RCH25
Clarke RWL-55
Clarke RWL-55
There’s no doubt this is aimed more at the pro than the DIY market, but it’s still within the reach of amateurs. It dwarfs our top two with a more conventional design that has a hinged bottom section combined with powerful magnets in the back and base, as on the Sealey and Ring. The Philips’ LEDs deliver 500 lumens, but in a relatively narrow spread. Although the light’s output can be adjusted by holding the power button, even at maximum it lasted more than three hours. A great, but not cheap, package.
Buy now from Philips
Draper 11767​
Draper 11767
Draper 11767
Sealey LED1801
Sealey LED1801
Laser 7056
Laser 7056
Draper 90187
Draper 90187
Philips RCH25
Philips RCH25
Clarke RWL-55
Clarke RWL-55
Pick this for maximum light. The COB LEDs punch out 1,000 lumens – the most powerful we tested, and delivered across a decent width. The battery ducked out after 90 minutes but would last a lot longer on the 500-lumen setting. There are charge and battery-state LEDs and a hinged base, but it lacks the Philips’ handy charging dock. Power at a decent price.
Buy now from Draper Tools
Draper 90187​
Draper 11767
Draper 11767
Sealey LED1801
Sealey LED1801
Laser 7056
Laser 7056
Draper 90187
Draper 90187
Philips RCH25
Philips RCH25
Clarke RWL-55
Clarke RWL-55
Draper’s folding-blade light is almost twice the length of the Ring when closed, and nearly three times as heavy. It also has a rotary dimmer for the 7W LEDs, which is useful because their 700 lumens will flatten the battery in two hours on full power. Less good is the inability to fold completely with the LEDs on the outside, and the lack of magnets in the back.
Laser 7056​
Draper 11767
Draper 11767
Sealey LED1801
Sealey LED1801
Laser 7056
Laser 7056
Draper 90187
Draper 90187
Philips RCH25
Philips RCH25
Clarke RWL-55
Clarke RWL-55
There’s lots to like about this. It’s similar to the Draper and Philips, but adds a hinged base that also rotates. It’s smaller, too, at 18cm tall with a 260-lumen output. The light is okay in small spaces but relatively narrow. It has a basic charge indicator but the options include a dock, UK and European mains USB adaptors and one for in-car charging. It’s decent, but others have an edge.
Buy now from Amazon
NightSearcher Tri-Spector​
Draper 11767
Draper 11767
Sealey LED1801
Sealey LED1801
Laser 7056
Laser 7056
Draper 90187
Draper 90187
Philips RCH25
Philips RCH25
Clarke RWL-55
Clarke RWL-55
The Tri-Spector has a tough job here, up against pure worklights while delivering a fair bit more. As a worklight it compares well with a 600-lumens and has a useful two hours-plus run time. Where it differs is the battery also powers a decent flexible light and effective spot-to-flood torch. If you can use these, then this is well worth investigating.
Clarke RWL-55​
Draper 11767
Draper 11767
Sealey LED1801
Sealey LED1801
Laser 7056
Laser 7056
Draper 90187
Draper 90187
Philips RCH25
Philips RCH25
Clarke RWL-55
Clarke RWL-55
There’s something very old-school about this light. It has a bank of 55 LEDs, with 33 giving a white work light and the rest a red emergency or flashing light. Output was nowhere near the latest designs’, nor was the run time. There’s also just one magnet on the back, and while there is a charging dock plus an adaptor for in-car charging, these are not enough to rescue this light.
Buy now from Amazon
Now you can see what you are doing, why not see which is the best socket set on sale to get the job done?
D
Dave Pollard
D
D
Dave Pollard
D
D
Dave Pollard
D
