NO matter how well lit your workshop is, or how bright the day, at some point you will need more light when you’re working on cars. Fortunately getting light where you want it has never been easier, because advances in LED and battery technology have seen the output of inspection lamps increase, and run times lengthen.
Cordless is the way to go, with the best lasting well over two hours, and no leads trailing across the floor or drive to trip over. Makers have also exploited the new tech to come up with innovative designs that make it easier than ever to put light where it’s needed. So which of the latest designs is the shining star? We charged eight to find out.
How we tested them
As designs have improved and converged, we have refined our test to find a worthy winner. We measured light output and beam spread, as well as assessing torches and the run time at maximum power. We also looked for power-saving modes, plus battery-charge and state indicators before heading under a wheelarch and bonnet for practical tests to see how easy it is to get light where it’s needed. The final factor was the price, which we obtained from online sources.
Ring’s MAGflex Slim narrowly beats the Sealey SlimFlex at its own game with a small yet versatile blade light. Philips’ more conventional design ticks a lot of boxes to complete the top three.
Ring MAGflex RIL3900HP – Best Buy
NightSearcher Tri-Spector
Philips RCH25
LED Inspection lamps - header
Clarke RWL-55
Sealey LED1801
Draper 90187
Draper 11767
Laser 7056
When you see how similar the MAGflex Pivot is to the Sealey it’s no surprise the two were closely matched, but the Ring just edges out the former winner here. The Ring is a smaller package, some three centimetres or so shorter when folded, but the COB (chip on board) strip still manages to push out 400 lumens. With a similar 2.6Ah Li-ion battery, it had the edge in the run time test, at almost four hours. Add in its keen price, a thumbwheel dimmer, plus charge and battery state indicator, and you have a winner.
Buy now from Amazon
Sealey LED1801 - Recommended
Philips RCH25
Clarke RWL-55
Sealey LED1801
Draper 90187
Draper 11767
Laser 7056
The LED180 was top in our last multi-test two years ago and now Sealey has boosted the power and output of the SlimFlex design, with the 12 SMD (surface mount device) LEDs punching out 500 lumens – up from 400. Yet it wasn’t quite enough to hang on to the crown. Its beam had the edge on the Ring’s, and the light had the same easily directed twist-and-fold blade. But it shut down after two and half hours in the run-time test and had neither a battery-state indicator nor, crucially, a mains adaptor for the USB charging lead.
Buy now from Sealey
Philips RCH25 - Recommended
Philips RCH25
Clarke RWL-55
Sealey LED1801
Draper 90187
Draper 11767
Laser 7056
There’s no doubt this is aimed more at the pro than the DIY market, but it’s still within the reach of amateurs. It dwarfs our top two with a more conventional design that has a hinged bottom section combined with powerful magnets in the back and base, as on the Sealey and Ring. The Philips’ LEDs deliver 500 lumens, but in a relatively narrow spread. Although the light’s output can be adjusted by holding the power button, even at maximum it lasted more than three hours. A great, but not cheap, package.
Buy now from Philips
Draper 11767 - Recommended
Philips RCH25
Clarke RWL-55
Sealey LED1801
Draper 90187
Draper 11767
Laser 7056
Pick this for maximum light. The COB LEDs punch out 1,000 lumens – the most powerful we tested, and delivered across a decent width. The battery ducked out after 90 minutes but would last a lot longer on the 500-lumen setting. There are charge and battery-state LEDs and a hinged base, but it lacks the Philips’ handy charging dock. Power at a decent price.
Buy now from Draper Tools
Draper 90187
Philips RCH25
Clarke RWL-55
Sealey LED1801
Draper 90187
Draper 11767
Laser 7056
Draper’s folding-blade light is almost twice the length of the Ring when closed, and nearly three times as heavy. It also has a rotary dimmer for the 7W LEDs, which is useful because their 700 lumens will flatten the battery in two hours on full power. Less good is the inability to fold completely with the LEDs on the outside, and the lack of magnets in the back.
Laser 7056
Philips RCH25
Clarke RWL-55
Sealey LED1801
Draper 90187
Draper 11767
Laser 7056
There’s lots to like about this. It’s similar to the Draper and Philips, but adds a hinged base that also rotates. It’s smaller, too, at 18cm tall with a 260-lumen output. The light is okay in small spaces but relatively narrow. It has a basic charge indicator but the options include a dock, UK and European mains USB adaptors and one for in-car charging. It’s decent, but others have an edge.
Buy now from Amazon
Philips RCH25
Clarke RWL-55
Sealey LED1801
Draper 90187
Draper 11767
Laser 7056
The Tri-Spector has a tough job here, up against pure worklights while delivering a fair bit more. As a worklight it compares well with a 600-lumens and has a useful two hours-plus run time. Where it differs is the battery also powers a decent flexible light and effective spot-to-flood torch. If you can use these, then this is well worth investigating.
Buy now from NightSearcher
Clarke RWL-55
Philips RCH25
Clarke RWL-55
Sealey LED1801
Draper 90187
Draper 11767
Laser 7056
There’s something very old-school about this light. It has a bank of 55 LEDs, with 33 giving a white work light and the rest a red emergency or flashing light. Output was nowhere near the latest designs’, nor was the run time. There’s also just one magnet on the back, and while there is a charging dock plus an adaptor for in-car charging, these are not enough to rescue this light.
Buy now from Amazon
Now you can see what you are doing, why not see which is the best socket set on sale to get the job done?
How we tested them
- Ring MAGflex RIL3900HP
- Sealey LED1801
- Philips RCH25
Philips RCH25
Clarke RWL-55
Sealey LED1801
Draper 90187
Draper 11767
Laser 7056
- Price: Around £30
- Rating: 5 stars
- Contact: www.ringautomotive.com
Buy now from Amazon
Philips RCH25
Clarke RWL-55
Sealey LED1801
Draper 90187
Draper 11767
Laser 7056
- Price: Around £38
- Rating: 4.5 stars
- Contact: www.sealey.co.uk
Buy now from Sealey
Philips RCH25
Clarke RWL-55
Sealey LED1801
Draper 90187
Draper 11767
Laser 7056
- Price: Around £70
- Rating: 4 stars
- Contact: www.philips.com
Philips RCH25
Clarke RWL-55
Sealey LED1801
Draper 90187
Draper 11767
Laser 7056
- Price: Around £43
- Rating: 4 stars
- Contact: www.drapertools.com
Draper 90187
Philips RCH25
Clarke RWL-55
Sealey LED1801
Draper 90187
Draper 11767
Laser 7056
- Price: Around £66
- Rating: 3.5 stars
Laser 7056
Philips RCH25
Clarke RWL-55
Sealey LED1801
Draper 90187
Draper 11767
Laser 7056
- Price: Around £53
- Rating: 3.5 stars
- Contact: www.lasertools.co.uk
Buy now from Amazon
Philips RCH25
Clarke RWL-55
Sealey LED1801
Draper 90187
Draper 11767
Laser 7056
- Price: Around £90
- Rating: 3.5 stars
- Contact: shop.nightsearcher.com
Clarke RWL-55
Philips RCH25
Clarke RWL-55
Sealey LED1801
Draper 90187
Draper 11767
Laser 7056
- Price: Around £36
- Rating: 2 stars
- Contact: www.machinemart.co.uk
Buy now from Amazon
