Hi guys, hope you are all well. Had problems with the Corvette as follows. Vats system kicked in so car wouldnt start. My neighbour solved the issue by over-riding the system . Then bought a set of Heddman hedders. Old headers nackered. Got my neighbour to fit them for me. Ran into a problem fitting new spark plugs as my heads not standard. Again, my neighbour solved the problem by modifying a nut headed socket , by cutting away one side of it. The car is now going to be fitted with a custom made exhaust system on the 24th of this month. When I started to move the Corvette off my neighbours drive, there was some fluid under it which turned oit to be petrol. On inspection, it was found that thefuel pipes were shot, front to back. Old pipes from tank to engine bay all cut out and replaced with new PTFE pipes. Even with the exhaust system missing from headers back, the car is running better than ever. Cant wait to get the exhaust completed. It will be back on the road in June, as will my Cossie.
