Decoded my VIN and noticed something odd.
Went to Free VIN number decoder for any cars
Typed in my VIN, most of the stuff I already knew. Under Trim Level, its Formula Coupe, not Trans-Am. hummm.
4 point ABS may be a grey area too, as there are two wheel speed sensors at the front, and one at the rear making it 3 point ABS.
VIN:2G2FV22G4Y2103955
WMI / VDS / VIS:2G2 / FV22G4 / Y2103955
Model:Firebird
Make (Manufacturer):Pontiac
Model year:2000
Manufactured in:Canada (North America)
Sequential number:103955
Body style:HATCHBACK 2-DR
Brake - front:Disc
Brake - rear:Disc
Brake system:4-Wheel ABS
Cargo volume:12.90 cu. ft. / 365.3 liter
Consumption in the city:17 miles/gallon / 13.8 liters/100 km
Consumption on the highway:25 miles/gallon / 9.4 liters/100 km
Curb weight:3433 lbs / 1560.5 kg
Driveline:RWD
Engine type:5.7L V8 OHV 16V
Fuel tank:16.80 gallon / 63.6 liter
Ground clearance:4.50 in / 11.4 cm
Overall height:52.00 in / 132.1 cm
Overall length:193.30 in / 491.0 cm
Overall width:74.50 in / 189.2 cm
Standard seating:4
Steering Type:R&P
Tires:245/50R16
Trim level:Formula Coupe
Turning Diameter:37.80 ft / 11.5 m
Warranty distance:36 000 mile / 57 000 km
Warranty duration:36 month
Wheelbase:101.10 in / 256.8 cm
Found a simular website.
  • VIN: 2G2FV22G4Y2103955
  • Year: 2000
  • Make: Pontiac
  • Model: Firebird Formula / Trans Am
  • Style / Body: Coupe 2D
  • Engine: 5.7L V8 MPI
  • Country of Assembly: Canada
Perhaps the Formula and Trans-Am are pretty much the same at the level of decode they are doing.
I think they are. They both came with the same engine/trans options. Formula vs Trans-Am was essentially an appearance package.
VIN:1G1FP23T3ML115618
WMI / VDS / VIS:1G1 / FP23T3 / ML115618
Make (Manufacturer):GMC, Chevrolet
Model year:1991
Manufactured in:United States (North America)
Sequential number:115618
Body style:COUPE 2-DR
Brake - front:Disc
Brake - rear:Disc
Brake system:Non-ABS
Consumption on the highway:27 miles/gallon / 8.7 liters/100 km
Curb weight:3107 lbs / 1412.3 kg
Driveline:RWD
Engine type:3.1L V6 OHV 12V
Fuel tank:15.50 gallon / 58.7 liter
Overall height:50.30 in / 127.8 cm
Overall length:192.00 in / 487.7 cm
Overall width:72.80 in / 184.9 cm
Standard seating:4
Steering Type:Recirc
Tires:215/65R15
Trim level:RS Coupe
Turning Diameter:38.50 ft / 11.7 m
Wheelbase:101.00 in / 256.5 cm
Got mine :)
Yours is over 100kg lighter, mind you I may be lighter at the mo ad no axle attached. lol. My MPG is only 2mpg on highways less than yours.
Wow, loads of option codes in there.
Interesting though its a Formula with a Trans-Am option code. I didn't know that, learn something new everyday. I think I learn many things new each day because I forgot I learned it once before.
