Written by Proto Labs: www.protolabs.com
A basic tenet of traditional manufacturing says that as part complexity increases, so do machining and assembly costs. But what if there were a different way to produce metal parts, one with fewer limitations than traditional milling, turning and grinding processes? And what if such a process was capable of building complex parts in less time and with little human intervention? Enter direct metal laser sintering (DMLS), more commonly known as industrial 3D printing. Through additive manufacturing technology, DMLS produces fully functional metal prototypes and end-use parts. It simplifies assembly by reducing component counts and offers virtually unlimited part complexity with no additional cost. Gaining Support DMLS works by slicing part models into paper-thin layers and then "drawing" them with a laser in a bed of powdered aluminum, stainless steel, titanium, cobalt chrome, Inconel and other metals. Starting from the bottom layer and working up, each metal particle is melted and fused to its neighbors, one layer at a time until the part is complete. The result is a fully-dense metal product with mechanical strength and fatigue characteristics little different than and in some cases exceeding one machined from comparable wrought, forged, or cast material. However, tooling costs are minimized and setup times and scrap are significantly reduced. Product designers and engineers who are ready to climb aboard the DMLS express should be aware of a few things first. Although DLMS technology produces fully dense parts from high strength, corrosion resistant metals, certain part features are prone to warping and curl if not supported properly during the build process. The design of build supports isn"t something you need to be concerned with. But you do need to know that some shapes are exceptionally difficult to build. And by altering your part design somewhat, costs may come down while product quality goes up. Learning the ABCs Let"s take the entire alphabet for example. One of the cool things about DMLS is you can print a number of different components in the same build, provided they fit within the machine"s build chamber. In Proto Labs" case, that space is a volume measuring roughly 10 x 10 x 10 in. (250 mm3). Let"s start with the letter A. Unless the horizontal crossbar is less than 0.080 in. (2 mm) across, vertical supports will be required beneath it to prevent warpage. Not a problem, but it"s going to cost a bit to grind or machine those supports away after the build. Same with a T without supports beneath the overhanging top section, it"s going to curl up like a goalpost. Letters B, D, P and R are especially problematic because the supports will be left inside the part, where they"re most difficult to remove. Curved shapes like O and Q fare no differently, unless the letters are quite small, about the diameter of a soda straw. In fact, about the only letters that won"t need any form of support are X and Y, provided the arms are angled at least 45 from the horizontal. Orientation Day So why not just lay the letters on their backs? "Voila!," you exclaim and go home early. In this case, all of the letter"s walls are vertical and the only support needed is a series of interconnected vertical braces between the bottom of each letter and the DMLS build plate. This is rather like scaffolding used to support construction workers. These are easy to remove once the build is complete and avoids direct contact with large, flat part surfaces that can warp or damage the build plate. This approach also provides the best surface finish, since roughness increases as walls deviate from vertical in DMLS-printed parts. It is worst on angled down-facing surfaces. Wall thickness is another consideration. Thin walls below 0.040 in. (1 mm) must maintain a wall height-to-thickness ratio of less than 40:1 or the structure may tumble. On the other end of the spectrum, very thick walls are wasteful and take a long time to build better to hollow them out with a honeycomb or lattice structure. This reduces material costs and processing time while preserving structural integrity. Indeed, lattice structures are one of the best tricks up an additive magician"s" sleeve. They"re virtually impossible to produce via conventional machining methods, but are fairly simple with DMLS. So too are treelike structures, gentle twisting seashell curves and other organic shapes, all of which are cost-effective to produce with 3D printing. All that"s required is a little imagination and the right CAD software. One final consideration: While Proto Labs encourages product designers and engineers to think outside the box, it"s important to keep an eye on the finish line. DMLS provides the opportunity to push the limits on prototype and low-volume part design, but it"s not yet viable for high-volume production because of economic factors. It is therefore an excellent idea to explain the entire product life cycle to someone knowledgeable in all types of manufacturing, so you don"t inadvertently design your product only to find it"s not scalable beyond a few hundred pieces.
Date written: 11-Feb-2017 10:20 EST
