So what is it?
A Bentley Continental V8 with a little extra. This is good news: since the arrival of the second-gen GT in 2012, the ‘base' 500bhp 4.0-litre V8 has been our pick of the engines over the more powerful 6.0-litre W12.
But this V8 S, says Bentley, is a car pitched at V8 owners ‘who want more'. It's priced at £139,000, some £16,000 more than the regular V8, which places it above the regular 567bhp W12 but below the range-topping, 616bhp W12 Speed on the price scale.
What do I get for my extra 16 grand?
More powerrrr. Twenty-one horsepowers more, to be precise, taking the twin-turbo V8's output to 521bhp and cutting the 0-60 time to 4.3 seconds, the same as the regular W12. V-max? 192mph. Sufficient.
Torque is up, too, from 487lb ft to 502lb ft, the whole lot on tap from 1700rpm right the way through to 6000rpm. Such grunt reaches all four wheels through an eight-speed ZF auto recalibrated to hold onto the gears for longer.
So it's thirstier, right?
No. Economy and emissions remain the same as the standard GT V8 (26.8mpg combined, 246g/km CO2), thanks in part to the V8's cylinder de-activation system, in which four cylinders are turned off under light throttle ‘cruising' conditions, the full eight coming on song when your inner Stig takes control.
Let me guess: it's lower, stiffer, pointier?
Correct. Bentley has dropped the GT's sports suspension by 10mm, increased the spring rates (up 45 per cent on the front, 33 per cent on the rear), revised the damping, stiffened the bushes by 70 per cent and rear anti-roll bar by 54 per cent, recalibrated the steering for ‘improved precision and feedback' and loosened up the stability control to allow for ‘increased wheel slip at higher speed'.
So how do I tell it's not a cheapskate standard Conti V8?
Externally, the V8S has a more aggressive front splitter, side sills and rear diffuser finished in Beluga gloss black. Check the wheels, too: our test car was fitted with the optional 21-inch alloys wrapped around the largest carbon ceramic brake discs ever fitted to a production car (420mm front, 356mm rear and yours for £10,405, cough).
And on the inside?
Inside the V8 S it's business as usual as you drop into what is one of the very finest interiors in the automotive world and surround yourself with quilted perforated leather, knurled aluminium dials and piano black surfaces all finished with a world-class build quality and millimetric accuracy that more than justifies the price of admission.
So what's it like to drive?
If you're taking it easy, very... Continental. The S has lost none of the GT's ability to devour huge distances while cosseting and relaxing the driver: drop the gearbox into D and this four-seater will cheerily burble across any continent you choose to point it at, with that dismissive poise that has cemented the Conti such a mighty GT car.
But the S is supposed to be for those ‘who want more' and it delivers. Drop the 'box into ‘S', gun the throttle and the V8 S rides its wave of torque all the way to 6000rpm, building speed in a way that no car weighing over 2200kg should, the optional sports exhaust serving up a very British baritone soundtrack.
Written By:- Charlie Turner
