Oh great, someone's been tampering with a Golf GTI.
Yes, the Golf GTI is such a respected all-rounder now that tampering with it seems almost indecent. It's as if Laura Ashley had started selling bondage gear. However, since VW itself isn't above adding extra power to the platform (see our recent drive of the new Golf R) maybe we should cut Milltek some slack. After all, the gains they've got from the 4cyl 2.0-litre turbo are, well, remarkable.
And what are they?
You might recall that if you buy a standard Golf GTI it comes with 217bhp. If you opt for the £995 Performance Pack that rises a dizzying 10bhp to 227bhp. Milltek has done better. Quite a lot better. This is 312bhp of better.
Jeepers, that really is quite a gain. What's been done?
Well, first and foremost Milltek is an exhaust company, so this car has a new bigger 3-inch bore exhaust which reduces back pressure and lets the gases escape more easily. There's also a bigger air filter, so air can get into the engine more easily, too. And finally they've let a company called Shark have a play with the ECU for them. These are all fairly standard performance upgrades, but it's not often you see such significant gains, which speaks volumes for how unstressed VW's standard engines are.
OK, but what about torque? I bet that hasn't gone up as much...
Um, 332lb ft actually, a gain of 74lb ft.
Phew. Has anything been done to the suspension to help it cope?
You probably spotted that it rides a bit lower than a standard GTI, so yes something has been done - it features Eibach springs and anti-roll bars. However, there are no changes to the electronic management of the traction control, nor a limited slip differential to help deal with the torque.
So does it torque steer outrageously?
Oddly, no. In fact the front end is amazingly well behaved - and for three key reasons. Firstly, it feels as if VW has got the suspension geometry absolutely nailed with this car. It tracks straight and true, feels benign and manageable. Secondly, the electronics have moved on a massive amount since VW first gave us a car with a pretend electronic differential, and lastly, the torque has been limited in first and second gears.
I take it this was necessary for gearbox preservation?
We have to assume so. But don't make the mistake of thinking it's slow through first and second, because it isn't - it's just that third and fourth gears move this car beyond the realms of almost anything else that could call itself a hot hatch. The trouble is that to enjoy all the fire in this Golf's belly, you need to use all the revs, and if you use all the revs in third... well let's just say you're doing over 70mph.
So it's fast then?
It genuinely is as quick as most of us would ever need a road car to be - really athletic and punchy, able to keep pace with a Boxster or unwary 911. And largely free from compromises. Largely. Because there were some small issues with our test car that need sorting, the biggest being the lower ride height that meant the tyres scrapped on the arches if you hit a speed bump or managed to load the suspension up enough through a corner. There was a bit of extra bounce through the suspension, too, but even with that and a slightly sleepier turbo, the changes haven't made this a faster-but-worse car. Instead it comes across as having a dash of attitude. It doesn't feel ill-mannered - despite the rubber-scraping noise.
Written By:- Ollie Marriage
