Although some rivals such as the Honda Jazz and Suzuki Baleno offer much more interior space than the Fiesta, the Ford is now on a par with its more well-rounded rivals such as the SEAT Ibiza and VW Polo.
The Fiesta isn’t just spacious - it’s practical in the sense that it’s easy to drive, and the driving position is excellent. It’s not just for the average person, though, as the amount of adjustment in the wheel and seat means taller and shorter drivers will be able to get comfortable.
Visibility is good, apart from the small rear window and thick C-pillars. Parking sensors or a rear-view camera are offered on all but the base Trend versions, which some will find very helpful.
Ford Fiesta - interior detail
Spend another £300 for and you get a ten speaker Bang & Olufsen stereo.
Ford Fiesta - panoramic roof
Ford Fiesta - front red
Ford Fiesta - rear red
Ford Fiesta - wing mirror red
Ford Fiesta - front static
Ford Fiesta - profile
Ford Fiesta - rear
Ford Fiesta - boot
Ford Fiesta - rear detail
Our Choice: Ford Fiesta Zetec 1.0 EcoBoost (100PS).
The interior is a big change with upmarket materials and a more modern layout.
The cabin has ergonomically placed controls, while soft-touch materials replace hard plastic panels.
Ford Fiesta - front seat detail
Ford has improved the Fiesta to keep it on top of the UK’s car sales charts.
Ford Fiesta - fog light
The changes made to rear end styling give it a different stance on the road.
It feels a little bit more spacious inside with decent space in the back seats. While the boot is slightly larger too, with a wider opening than before.
Ford Fiesta - dials
The design change is evolutionary as the car used the same platform as before.
Ford Fiesta - wheel
Ford Fiesta - front light
Ford Fiesta - transmission
You get to choose from a basic 6.5-inch system and an 8-inch running Ford’s SYNC3 software.
Ford Fiesta - front action
Ford Fiesta - front cornering
Ford Fiesta - sat-nav
The Ford Fiesta is 71mm longer and 12m wider than the previous model, and the wheelbase is 4mm longer as well which helps with legroom in the back. In total, it’s 4,040mm long, 1,735mm wide, 1,466mm high and has a wheelbase of 2,493mm.
That makes it a little thinner than a Nissan Micra, but it is longer and taller and has a longer wheelbase. However it’s only by a matter of millimetres and most cars in this class are pretty much the same size on the outside; it’s the inside that really sets each model apart.
Ford says there’s an extra 16mm of legroom in the back of the new Fiesta, and it does feel a little bit more spacious than before. It’s not as cavernous as a Suzuki Baleno or Honda Jazz in the back, but there’s more than enough leg and headroom even for taller adults in the back seats. The seating position in the back is a little bit too upright for total comfort, but for the kind of journeys buyers will use it for that won’t be a problem.
In the front there’s lots of space and both driver and passenger will be able to get comfortable thanks to the amount of adjustment offered in the seats.
Ford Fiesta - rear
Ford Fiesta - boot
Ford Fiesta - dials
Ford Fiesta - wheel
The Ford Fiesta is now available with 311 litres of luggage space with the seats up, and 1,093 litres with the rear seats folded down - a little more competitive, but not by much, as most cars in this class have a boot of a similar size.
The boot opening is wider than before too, which makes getting big items in and out easier. The loading lip is still quite high up, which hinders sliding in long items. However, for £75 you can add a variable boot floor, which can be raised to create a flat load area with the rear bench folded.
	Ford Fiesta - rear
	Ford Fiesta - boot
	Ford Fiesta - dials
	Ford Fiesta - wheel
Size
- SEE MORE Smallest cars on sale in the UK 2021
	Ford Fiesta - rear
	Ford Fiesta - boot
	Ford Fiesta - dials
	Ford Fiesta - wheel
Boot
