The MAF sensor measures air in grams per second. It sits after the air filter and before the throttle body. It is made up of some wires across the air flow, with that is calculated the air flow.
The faster your engine revs the more air your engine requires.
That being said while doing some loud pedal runs I have noticed some bad readings from the MAF.
Why does this look bad? Well where the cursor is, it appears to be working okay MAF reading 301g/s of air @ 5843RPM, but to the right of that Revs keep rising and MAF value drops off. Foot still too the floor indicated by throttle position. the MAP sensor (manifold air pressure) is reading correct and still high at the same point the throttle position is.
Q. Was this just a freak occurrence?
A. No, it done the same in 3rd gear
Am I pegged out of the MAF capacity? no, it is capable of 500g/s.
Is the MAF dirty, well possible, but why drop off at that point?
Done it again in 2nd gear at a lower RPM.
I can unplug the MAF and run in a mode called Speed Density. It will use the MAP sensor to meter the air.
I can buy a new MAF, but would like to go a larger diameter, but while doing that need a larger air box, larger throttle body and larger intake, so that is a plan down the road a bit. So prefer to hold off on the MAF replacement for as long as possibe. So running without the MAF may be best.
You may wonder why the engine goes rich when the MAF readings drop off, well that is a safety thing I luckily had in there, as the car was going to command 14.6AFR as it doesn't think i was putting the engine under load.
