P
Pete Baiden
Alex Ingram 2020-02-18 23:01
The new Hyundai i20 supermini takes the fight to the Ford Fiesta and Renault Clio with more space and efficient engines
This is the new Hyundai i20, which is due to hit showrooms in September. The new supermini aims to steal a march on talented rivals such as the Ford Fiesta and Renault Clio by delivering superior safety kit, class-leading in-car entertainment and mild-hybrid powertrains.
While the i20 uses a heavily updated version of the current model’s platform, from a design point of view it takes a radical departure from its predecessor. It’s the first Hyundai to use the company’s new design language, which means more sharply defined body surfacing and angular headlights (featuring full LEDs on top models), which blend into the edges of the wide grille.
• Best superminis on sale
At the back, the new model gets a full-width strip connecting the tail-lights, and they sit below a panel which, when combined with a black contrasting roof, blends into the rear window. Beyond the black roof, there are also four new exterior paint colours to choose from. The sportier stance is helped by the overall shape; the new i20 is 24mm lower, 30mm wider and 5mm longer than its predecessor.
Image 2 of 16
Image 2 of 16
No official cabin shots have been issued, but Auto Express has seen the finished model and it does take a great leap forward over the current car. Top-spec versions feature a pair of 10.25-inch digital displays on the dash: one digital instrument panel with graphics that change according to driving mode, and a second touchscreen system that controls the infotainment. Base cars get a small 3.8-inch LCD panel, while an eight-inch touchscreen is also available.
Elsewhere, the i20’s overall wheelbase has grown by a modest 10mm, but a small increase in interior space beyond the last i20 – already one of the most spacious superminis – gives Hyundai ground to claim that this is one of the most practical cars in its class. Boot space is up by 25 litres too, to 351 litres – not quite as large as the new Clio’s, but 48 litres more than in a Fiesta.
The i20’s petrol-only engine line-up is related to the previous car’s, but each unit gains efficiency tweaks to reduce fuel consumption. While other markets are set to get a 1.2-litre with 83bhp and a 1.0-litre turbocharged 48-volt mild hybrid with 118bhp, the UK is likely to get just one engine: a 99bhp 1.0-litre three-cylinder turbo mild hybrid. This set-up recovers energy that would otherwise be wasted under deceleration, and can redeploy that power to reduce load on the engine.
Gearbox choices are either a seven-speed dual-clutch automatic or a new six-speed manual. The latter features an electronic clutch, which is able to decouple the gearbox from the engine when coasting to save fuel.
Efficiency is also improved courtesy of the fact that the new i20 is roughly four per cent lighter than the outgoing model – a result of lighter seats, plus a plastic fuel tank in place of the old car’s steel item. The i20 features a flap in the front grille as well, which improves aerodynamic efficiency (itself saving roughly 2g/km of CO2). All of these changes mean the new car is estimated to be up to four per cent more fuel efficient than the old i20.
Performance figures have yet to be revealed, but the lighter body is likely to have a positive effect here, too. Prices have yet to be confirmed, but are likely to rise slightly, starting at around £15,500.
Do you think the Hyundai i20 can jump above the Renault Clio and Ford Fiesta to lead the supermini class? Let us know below...
Associated Advanced Gallery
New 2020 Hyundai i20 arrives with hybrid power - pictures
Image 2 of 16
Image 2 of 16
