New 2021 Audi RS 3: 395bhp mega hatch priced from £50,900
S
Sean Carson
After months of teasing and drip-feeding specifications, Audi has finally unveiled its 2021 RS 3. Available in five-door Sportback guise to rival the Mercedes-AMG A 45 S and a four-door saloon, the new Audi RS 3 will start from £50,900 when it goes on sale in August this year.
Audi has already previously confirmed mechanical specifications for the RS 3 - including its clever new RS Torque Splitter rear differential - but this is our first opportunity to see the car uncamouflaged, as well as take a look at the interior.
Reinforcing its status as the A3 range topper, the RS 3 features a new, wider single-frame grille complete with honeycomb mesh for its large air intakes that help cool the 395bhp 2.5-litre five-cylinder turbocharged engine. The grille is flanked by a pair of standard-fit LED headlights; matrix LEDs, available as an option, will depict a chequered flag on unlocking the car.
There’s plenty of RS badging at the front and rear, while the car’s front wings feature large cut-out vents at the trailing edge of the panels to help expel air from the engine bay, plus the boxy flared wheel arches Audi’s RS products are known for to cover the car’s wider track width; it has been stretched by 33mm over its predecessor on the front axle.
Redesigned black side skirts give the RS 3 extra visual presence, along with the new 19-inch alloy wheels with a 10-spoke Y design. Optional five-spoke Y-design alloys will be available. They’ll be wrapped in bespoke semi-slick Pirelli P-Zero Trofeo R tyres on continental models, but the UK market won’t get this option.
Audi RS 3 Sportback - front static
Audi RS 3 Saloon - rear action
Audi RS 3 Saloon - rear tracking
Audi RS 3 Saloon - cabin
Audi RS 3 Saloon - front tracking
Audi RS 3 Sportback - full front
Audi RS 3 Sportback - front tracking
Audi RS 3 Saloon - dash
Audi RS 3 Saloon - rear static
Audi RS 3 Saloon - full front
Audi RS 3 Sportback - front studio
Audi RS 3 Sportback - wheel
Audi RS 3 Sportback - rear
Audi RS 3 Sportback - dash
Audi RS 3 range 2
Audi RS 3 range 2
Audi RS 3 Sportback - rear static
Audi RS 3 Saloon - front action
Audi RS 3 range
Audi RS 3 range
Audi RS 3 Sportback - rear tracking
Audi RS 3 Saloon - front static
Audi RS 3 Saloon - rear studio
Audi RS 3 Sportback - front seats
At the rear, a deep bumper houses a central diffuser element and the RS 3’s dual-exit sports exhaust, which features variable flap control linked to the car’s drive modes.
This new generation of RS 3 is available in two exclusive colours, called Kyalami Green and Kemora Grey, while other visual options include carbon fibre on the side skirts, door mirror caps and the tailgate roof or boot lip spoiler on the hatchback and the saloon respectively.
Inside, the RS 3 features more carbon fibre for the instrument panel, while specific RS sports seats embossed with the same logo fix the front occupants in place. Silver contrast stitching is standard but can be had in green too. A flat-bottomed three-spoke steering wheel with zinc-plated shift paddles also features.
There are updates to the infotainment as well, with a bespoke RS skin for the car’s 12.3-inch Virtual Cockpit plus digital dash, with a new ‘RS Runway’ option to display engine revs. The central 10.1-inch touchscreen also features Audi’s RS Monitor, which gives readouts on the tyre pressures, as well as the brake, differential, gearbox and engine temperatures.
Of course, there’ll be plenty of personalisation potential, with the option to add more extras to customise the look of the car - and increase its price further still.
Audi RS 3 range
Audi RS 3 range
Audi RS 3 range 2
Audi RS 3 range 2
As a baseline, Audi has confirmed that the new RS 3 Sportback will start from £50,900, while the RS 3 Saloon will be priced from £51,900. Both models go on sale in the UK in August, with deliveries beginning towards the end of the year.
New 2021 Audi RS 3: engine, chassis and performance​
Audi’s new hyper-hatch uses the German firm’s familiar 2.5-litre turbocharged five-cylinder petrol engine, producing 395bhp and 500Nm of torque. While torque is up by 20Nm compared with its predecessor, overall power remains the same.
However, Audi has focused on broadening the engine’s power band so it now produces its maximum from lower down in the rev range - from 5,600rpm, sustaining it to a higher engine speed, now at 7,000rpm.
The maximum 500Nm torque output is produced from 2,250rpm to 5,600rpm, with the engine’s motive force sent to all four wheels through a seven-speed dual-clutch automatic gearbox and a new all-wheel drive system.
Combined with launch control,the RS 3 delivers a 0-62mph time of 3.8 seconds (0.3 seconds faster than its predecessor), while top speed stands at 180mph if the RS Dynamic package and carbon-ceramic brakes are optioned, the latter saving 10kg over the standard steel items.
Audi RS 3 range 2
Audi RS 3 range 2
Audi RS 3 range
Audi RS 3 range
The new quattro four-wheel drive set-up features Audi’s RS Torque Splitter, a clever rear differential that can divert up to 100 per cent of the engine’s drive torque sent to the rear axle to one individual wheel.
With no discernable difference in weight between this set-up and the previous RS 3’s Haldex four-wheel-drive tech (the five-door Sportback weighs 1,570kg, while the saloon comes in 5kg heavier), Audi claims the switch vastly improves the new car’s handling and dynamic ability.
The system is linked to the different driving modes. Comfort/Efficiency prioritises power to the front wheels, Auto mode sees the split balanced intelligently, Dynamic applies more torque to the rear to boost agility, while RS Performance mode ramps things up even further. It is designed for track use, optimising the engine and transmissions settings, as well as using the RS Torque Splitter and torque vectoring to help reduce understeer and oversteer.
However, in the RS Torque Rear setting, torque is specifically directed to the outside rear wheel, allowing for controlled drifts and even more adjustability on the throttle. Three ESC modes (on, ESC Sport and off) determine how much drift angle the car will allow.
Audi RS 3 range 2
Audi RS 3 range 2
Audi RS 3 range
Audi RS 3 range
Plenty of chassis tweaks compared with the S3 hot hatch allow for the RS 3’s increased performance. The car’s ride height is 10mm lower than the S3’s, while at the front the RS 3 uses MacPherson strut suspension with unique pivot bearings, strengthened lower wishbones and a more rigid subframe.
Adaptations at the rear to accommodate the new RS Torque Splitter diff include a multi-link axle design with separate springs and shock absorbers, a bespoke subframe and a new anti-roll bar.
There’s also more negative camber for the RS 3 (just under one degree at the front and half a degree more at the rear), while reinforced wheel carriers help cope with the increased lateral loads from the new car’s extra grip.
A passive suspension set-up is standard with specific tuning for the RS 3, while the optional ‘RS sports suspension plus’ features adaptive dampers. The latter system is linked to the driving modes, with ‘comfortable’, ‘balanced’ and ‘sporty’ damping profiles available.
An RS-specific variable steering ratio set-up varies the speed of the steering depending on the steering angle, helping stability around the straight-ahead but boosting turn-in response in corners.
Click here for our list of the best hot hatchbacks on sale right now...
