opps didnt look that fast
Wow, that's a pretty hard impact to get the wheels off the ground.
Did he grab the hand brake instead of the gear stick?
Something not right there car was flat coming In no need to brake as open road ahead looks like a fault with the rear brakes as they lock up before the fronts
Yup - brake bias.
It does take a while to get it right if you have adjustment. When I did away with the ABS on the 97 Trans Am I had to install a proportioning valve to set the brake bias as previously the ABS module did that.
It took me a while and a bit of testing to get it right by the seat-of-the-pants-ometer. Then the MOT machine showed brake effectiveness and I had it virtually right.
