I have a wide-band gauge int he car, made by AEM. I have had one in the car for many years. This one was new since the engine rebuild.
What does it do. Well its a sensor in the exhaust that measures Air/Fuel ratio, a great tool for tuning to get the correct fuelling, and effectively more power out of the engine. There is a display on the dash, and also give out an analogue voltage I can datalog with my tuning software.
The one on my car seems to be stuck in the heat cycle. I contacted AEM for some clues. They said to check earths and that. I'm getting good voltage, and earth points appear to be good. So the next step in the diagnosis is to replace the sensor, if still not working. I'll swap out the pod. This is the exhast same model I have. There are many models, I went for the same one so I can swap out parts. I may even be able to repair my old one so I have a spare.
My previous one came from the states. As these are used on and tuning cars, I thought I'd check Demon Tweaks in the UK (where I got the Koni shock from) and they have them. It should be delivered tomorrow according to the tracking
