Plymouth Barracuda 383, low miles For Sale (1973)
Ive decided after 38 years of ownership to sell my Cuda.<br />
<br />
1973 Barracuda 31,000 miles from new<br />
<br />
all steel original body panels, and interior only non original interior part is the headlining which was professionally done and perfect.<br />
<br />
The car has been sympathetically modified to both look stock while making it easier and better to drive anywhere.<br />
<br />
Painted over 20 years ago in Ford Amalfi blue with brilliant white Billboards,<br />
paint now has a few blemishes but nothing bad.<br />
<br />
The list of Parts are, <br />
Msd Ignition 6AL<br />
MSD billet distributor<br />
Taylor leads and protective boots<br />
MSD rev limiter and dial select<br />
Kenlowe fan<br />
B&M trans cooler<br />
Cal custom Rocker covers<br />
Aeromotive A1000 fuel pump return to tank system,fuel filters and fuel log<br />
Sumped stock fuel tank<br />
holley 800 cfm DP carb<br />
Braided fuel lines to and from carb to tank<br />
Holley street dominator single plane intake<br />
Comp cams custom ground cam, solid lifter<br />
Brake accessory vacuum pump for power brakes and twin reseviors<br />
Yella Terra roller rockers<br />
Vulcan engineering ported and polished 906 heads <br />
Hauser race cars fitted 2.18 1.88 valves <br />
TRW 12.5 :1 forged pistons<br />
Hauer deep sump and modified oil pick up and system<br />
Mini starter<br />
4 core Iveco truck core Radiator with stock top tank, looks original buts 1000 times better.<br />
Built 727 transmission with reverse pattern manual valve body (manual shift auto) easy to use...just like flappy paddle box in effect. <br />
JW 10inch 3800 convertor<br />
B&M pro stick shifter with Gunslinger real wood handle<br />
Nos cheater system 200 hp<br />
but running with sure shot small solenoids so easy up grade if needed...( of course you do)<br />
Monster tacho and <br />
Autometer gauges fuel press, water temp, amps, oil press. <br />
sub frame connectors, Mopar Super stock Springs moved inboard on mopar relocation kit.<br />
with KYB rear shocks and 90/10 up front but also stock KYB included.<br />
Centreline Pro Stock wheels <br />
5 x 15 front and 10x 15 rears<br />
Richmond 4:10 rear gears and Mopar POSI diff<br />
pinion snubber all built and set up at Geof Hausers<br />
383 Engine was also Built By Geof Hauser.<br />
Hauser race cars half roll cage<br />
Dodge Viper front brakes and bias adjuster.<br />
Full Harness.<br />
Hooker Super comp Headers<br />
Full 3 inch flowmaster exhaust system by APD<br />
....and much much more I cant remember.<br />
<br />
needs to be seen, Lovely looking and Very well known car.<br />
<br />
Car also runs 12.00 Deads on the strip<br />
<br />
this isa proper Muscle Car that drives like a kitten, until you jump on the Loud pedal.....then HOLD TIGHT...its crazy quick and sounds wonderful.<br />
<br />
Private... CUD4 V.... PLATE NOT INCLUDED IN SALE, SORRY <br />
<br />
27K ovno<br />
<br />
Steve 07904252995<br />
super driving car, drive anywhere.<br />
<br />
<br />
Date written: 04-Mar-2016
Price: £27000 As stated
Nice but unsure about clolor,
