Pro street chevelle,built by street toys usa,p/x For Sale
1972 pro street chevelle<br />
sell swop part exchange<br />
built in juarez mexico,by street toys,(see link)a well known and well respected hot rod shop,at the cost of 70k+,<br />
taxed (free) moted and road registered,v5 log book in my name.<br />
fully pro street back end,fitted with all the right bits,this car is built to a exceptional standard,with no expense spared.383 stroker motor,auto,full cage,tubbed and bead rolled alloy paneling through out.all gauges work this is a finished car,of show winning standard,never been on a drag strip or show field in this country.<br />
<br />
parts used in build:<br />
<br />
a stroker conversion kit chevrolet cid 383 <br />
eagle forged pistons radio with compression 9. 1 <br />
eagle bore.030 <br />
chrome molly rings <br />
crankshaft steel eagle rods steel eagle i beam <br />
aluminium heads edelbrock performer rpm<br />
2.02 oil pump meling <br />
hi-volume metal rods<br />
clevite 77 key gear metal<br />
clevite 77 camshaft <br />
comp cams 290 performer rpm intake manifold kit <br />
comp cams time holley <br />
street avenger carter milodon 9 lts oil pickup<br />
oil milodon roller rockers<br />
1.7 comp cams alum push rods<br />
chrome molly comp cams<br />
mini starter jegs<br />
external balance flex plate damper<br />
crankshaft external balance <br />
gm alternator 100 amp chrome<br />
transmission tci- th400 <br />
bem 2500 rpm high stall converter <br />
headers jet coated<br />
differential 9"" shortened positraction backside lsd<br />
suspension 4-links engineering competition <br />
adjustable coilover set <br />
disc brake conversion<br />
ssbc leaf spring and control arm bushings <br />
gm disc brake disks<br />
drop 2"" sway bars kit<br />
set of auto meter gauges<br />
2-5 / 8 and 5"" rin auto drag front tire <br />
15x7 centerline 28 x 7.5 m / t sportsman rin centerline 15x12 rear tire auto drag 29 x 15.5 m / t <br />
5-way harness <br />
rjs pro street drag race seats & seat covers<br />
40-flow master series exhaust street rod kit<br />
aluminized 2-1 / 2 arp bolts kit <br />
aluminium radiator<br />
electric fans kit<br />
full fuel cell <br />
msd pro-billet distributor <br />
msd ignition <br />
blaster 3 coils<br />
msd 6al 11 mm wire set<br />
b & m pistol-grip <br />
shotgun billet scoop<br />
wheels steering grant <br />
<br />
more pictures available at http://streettoysmx.com/72chevelless.html<br />
<br />
no messers this is a serious car.<br />
please ask your mum,wife,girlfriend or partner before you enquire,to make sure its ok to spend the money!!<br />
no test pilots.<br />
we are in orpington north kent<br />
4 miles from j4 on the m25<br />
br6 post code<br />
please call:- tony 07971 689 744<br />
Date written: 07-Apr-2016
Price: £25995 Or near offer
