Well decided to go Solar Panels, did think about it around 3 years ago. A few companies were out there saying they give you free panels, I guess they get their money back by effectively renting your roof. However my roof is an odd shape and they wouldn't do anything our of the norm. I found a company recently that design a system for your needs, you choose how many panels you want. Up to 4Kw system gets more money per kWh than if you have larger system. I went with a company called ProjectSolar. Checked various review, and so many were positive.
The surveyor came around chatted about the system, measured up. The system should generate 3500kWh per year, my electric usage last year was 2500kWh, so thats a good start, I use less than I generate. So my electric bill should be free for ever now as the energy I sell back to the national grid should our weight what I buy in. So deposit paid on 24th Oct 2015. The system will be installed this Thursday coming 29th October 2015.
Some time ago well about 2.5 years ago I brought floorboards and beams for the left. Where the left insulation is very thick now, there is no point compressing it, so I brought the beams to raise the floor level by 4 inches. As the solar install team will need access to the left, I thought well its about time I got my finger out ans get the floor down up there. Took Friday off work spend the whole day up there. Quite a bit of time was used just moving stuff around, like moving the 8ft long boards on top of the boards I've already put down so they are out of the way. So I got a few hours in at it over the weekend, and took Monday off work to carry on. Floor all complete now. Its great, gonna be soo much room for more storage.
The solar panels are going on two roof faces as the front of the house gets the morning sun, and the side gets the evening. The panels are quite wide angle so at mid day both will be generating power.
View attachment 59249View attachment 59250View attachment 59251
Ran out of 2x4 beams, need around another 12 meters. There is a local saw mill that sells wood at a very good price called Goodwillies. I need it in 1.5meters lengths, although the Trans-Am can take 2.4meters long. So I nipped down there, they do 3 meter lengths and give you a workbench and saw to guy your own wood, so directly in half worked out perfect. Fitted in the Trans-am too.
So quickly got these screwed down and popped some boards over the top, and job done
Now to wait until Thursday.
