THE STUNNING ICONIC SHAPE 1940 FORD PICK-UP NOW HERE IN THE UK...<br />
<br />
HAPPY TO REGISTER ON UK A V5 FOR NEW OWNER AT LISTED PRICE...<br />
<br />
HD PICTURE LINK.... pix.sfly.com/xo0aj-u8<br />
<br />
This 1940 Ford is 100% steel and built with only top shelf, name brand products.<br />
<br />
This build started with an impeccably restored original 1940 Ford. The vehicle was painstakingly disassembled by a seasoned hot rod builder.<br />
<br />
Chrome parts were all packaged up and sent out for re-plating while the frame was delivered to none other than Martz Chassis in Bedford, PA where it was professionally boxed for strength, new coil-over suspension was installed front and rear, dual stainless exhaust was added as well as a 20 gallon stainless steel fuel tank. Then it was all broken down again and prepped for a show quality paint job that matches the body. The chassis now rides on staggered Budnik Custom billet aluminum wheels, which are fitted with 205/65/15 up front and 255/70/15 out back. The wheel/tyre combo tuck under these smooth fenders perfectly for that bitchin look.<br />
<br />
The 383 Chevy engine is complete with Corvette heads, Sanderson headers, 4 barrel carb, and a mild street cam. The transmission is a Turbo 350 automatic controlled by an authentic Gennie Shifter. It has a bullet-proof 9 inch Ford rear-end with parallel four bar coil over and panard bar. It has an emergency brake.<br />
<br />
This is an all-steel body. The body was sent to The Hot Rod Garage, Inc. in Denton, MD. You can check out their amazing work at http://www.thehotrodgarage.com . Once there, the steel body was carefully gone over by their fine craftsmen and any imperfections were addressed.<br />
<br />
The wiring harness is a Ron Francis wiring harness. The fuse panel is in the glove box. <br />
<br />
The rest of the interior is equally as impressive as the exterior with custom leatherwork done in white by The Hot Rod Garage. The dash was replaced with a custom unit that houses a new tilt/power steering column, push button start, custom wrapped billet steering wheel, and all new VDO gauges.<br />
<br />
The truck has 5500 miles on it and is in very very nice condition and ready to show..<br />
<br />
REALLY THINK THE 1940 FORD DELUXE PICK UP IS THE BEST SHAPE PICK-UP ON THE PLANET....<br />
<br />
CONTACT ME ON 07545 376678 IF I CAN HELP REGARDS PAUL<br />
Date written: 17-Feb-2018
Price: £34995 As stated
