Written by Stephen Dobie
Just in time for, erm, autumn, it"s the Aston Martin DB11 Volante. Yep, a year or so after the coupe, the DB11 is now available in convertible form.It retains lots of stuff from the coupe its four seats, its three-stage engine and suspension settings, its limited-slip diff and torque vectoring but adds, predictably, a folding roof.Aston has stuck with a traditional fabric setup, which opens and closes in around 15 seconds. You can operate it up to 30mph, and in crosswinds of up to 30mph.If you"re worried fabric won"t insulate as well as a (heavier) metal setup, then Aston says it"s eight-layered with the latest acoustic technology. The roof and the car it"s attached to, actually have been tested in the Arctic Circle and Death Valley to prove its ability to keep out the cold and heat.The DB11 rides on Aston"s latest chassis, which is stronger than the DB9"s, so the Volante needs less reinforcement to counter the folding roof. As such, the DB11 Volante weighs 26kg less than the DB9 Volante. All told, it weighs 1,870kg, which is 110kg more than a V8-powered DB11 coupe.And a V8 is the only engine you"ll get in the Volante. While the coupe launched as a V12 and gained an AMG-sourced V8 a year later, the additional weight of convertiblisation (it"s a word) means Aston won"t put the heavier V12 in the Volante"s snout. The Volante"s weight penalty over a coupe is the same as the V12"s over the V8, so Aston is keeping mass in check by not allowing both to happen at once.That means a 503bhp twin-turbo V8 like you"ll find in AMG sports saloons, only tuned to sound (and deliver power) like an Aston should. It"s superb in the coupe, and turns it into a proper little tearaway to drive, so mourning the V12"s loss is time wasted.
Date written: 13 Oct 2017
