A wideband is very useful for tuning the car. It lets you know your Air to Fuel ratio. The car has regular lambda sensors just just say if its rich or lean but not by how muck. The Wideband lets you know how much. 14.6afr is around where the lambda sensors switch. For full throttle tuning you may want between 12.5 and 13.1 depending on RPM.
When data logging various sensors on the car I can plot the AFR too. However I have a problem with mine. It starts to warm up, appears to complete and then restarts the heat cycle. Feeling the sensor in the exhaust it is getting warm. Wiring all looks good. It has worked before.
[video=youtube;-MWHiwR2zUE]http://www.youtube.com/watch?v=-MWHiwR2zUE[/video]
I don't know if it's the sensor or controller that's at fault.
