Various items for sale can bring with me to beuliue 17th june.
20180613_144014.jpg20180613_144424.jpg20180613_144745.jpg20180613_145314.jpg20180613_152835.jpg
Will do prices in order of pictures . i can bring with me to beuliue on the 17th june .
pic 1 air filter used done about 100 miles as I have thinner air filter on my holly carb £5
pic 2 gm 7.5 crush sleave and gm 7.5 shims ordered in error as clicked wrong button i needed 8.5 £1.5 the pair all new
pic 3 exhaust flange bolts check code D3129 from summit as bolts look big to me new un used £2.5
pic4 4.6 clutch plate press bolts new unused £2.5
pic 4 2 head light adjustment screws with square holding clip left over from box qty £1.5
pic 5 HT LEADS OR AS ROCK AUTO CALL THEM SPARK PLUG WIRE SET ,
check part number for your application both sets ordered in error as these DO NOT FIT HEI distributer caps with the male ends on cap both of these lead set are for female type caps
left hand set have angled plug lead cap and straight push on ends for dissy £10 also has the coil lead
right hand set has angles caps both ends £15 also has coil lead
both sets un used as mentioned don't fit HEI dizzy caps.
pic 6 new un used as just been sitting on my self i brought one of those air compression with tank combi kits as i will never be likey to use these items
(only us the tyre pressure gauge) £10
pic 7 gm seatbelt clip hanger thingy un used paint to your color 1 base 2 holders £3
pic 7 gm stop tail light lamp holder 3 wire type £2.5
pic 8 2 rad hoses for gm truck standard size for el camino but mine has larger bore rad and hoses so don't fit check part number might be of use for another project ? £5 the pair.
Think that it for now,
Wow, you have been busy,
No takers then so all staying at home less to carry lol,,,
