WCX17: FCA reveals hole-istic" new lightweighting approach
Written by Bill Visnic
Engineers at FCA revealed at the SAE"s recent WCX17 conference in Detroit a new simulation and analysis design tool that can earmark nearly any suitable component for a strategic hole-punching process that can significantly reduce the part"s weight. Using a pickup-truck frame as an example, engineers reduced its weight by 15 lb (7 kg) but cutting optimally-placed and -sized holes and slots. The cutouts are located at places that the analysis shows have no impact on the frame"s fatigue or durability properties. By using two specific new simulation algorithms that discretely focus on fatigue performance as the design target, the simulation reveals non-critical areas that are over-engineered and thus are potential candidates for drilling holes or slots to remove material. A large component such as a truck frame could have the potential to cut weight somewhere between 3-5% by employing the new design simulation. Engineers presenting the results of the prototype process said that by first focusing on fatigue performance as the design target, the need for intermediate design goals is eliminated, so the new process itself is highly efficient and can help reduce development time. And they said the algorithms used in the process can be applied to the design of nearly any component. The engineers who authored the SAE technical paper (2017-01-1348) describing the new simulation approach, Barry Lin, Ramachandra Bhat, Shawn Zhang, Taylor Sykes-Green, Nitin Sharma and Kevin Thomson, explain, "Comparing to other optimization processes which typically convert fatigue targets to other design targets such as stress targets, this lightening-hole approach directly uses fatigue targets in the process. It eliminates the need to create intermediate targets and simplifies the whole process." They add that the strategy can be easily integrated into conventional design and analysis processes. An FCA source said that although the company has in the past drilled holes in components to lighten them, this new process has yet to be deployed in the design of a production component, although it seems likely it will soon be used perhaps to reduce weight for a refreshed Ram pickup, for example, which should soon be scheduled for launch. <br />
Date written: 06-Apr-2017 03:26 EDT
