Since I optimised some thing in the engine bay, I get the ABS light and Brake light on.
Found a post where yo can join wires
I shall give this a go and post pictures.
if you're looking at the ABS connector pin 12 is ground
Shorting Pin 7 to pin 12 will turn off the ABS INOP light.
Shorting Pin 16 to pin 12 will turn off the BRAKE light. (The light functions normally, indicating when the E-brake is on or off)
