Fitted the tank in place today. Straps secured, locking nut on the top of the tank all done up.
So the time to try to start it. It's not firing up. Well yesterday I tested fuel comes out of the tank. So I test the schrader valve on the intake. Nothing. Next to disconnect the fuel pipes to the engine. See no fuel coming out there.
Is it not coming out of the fuel filter, I disconnect that. No fuel there.
Take off the filter, I can blow through it.
Tested the pump with the tank in its correct position. Pump running. Did hear a gurgle before.
Perhaps not enough fuel to reach the pick up. The top of the tank is horizontal. We can see when it was above the pit it was more of an angle.
So hopefully it's lack of fuel and not that little rubber pipe again in the tank.
