Well more event happened last night. I went to the gym after work, and got totally knackered, I use the fiesta for to and from work. I get home and then have the idea of turning the trans am around in the driveway. The point of this is to put the car into the garage back first, so if the engine needs to come out then it can.
The drive way has a bit for a dip in it, meaning the car bottoms out, making scrape when driving the car in and out. So I built up the drive with some planks of wood.
So I started the trans-am, it fired up straight away. This new ticking noise wasn't there. Reversed the car out into the road, then it cuts out, sometimes it does this after starting (idle tuning need attention on cold start-ups) so I try to start it, the starter just clicks. The car is now on a slope aiming toward someone elses driveway, and I'm sitting diagonally across the road. I'm in my shorts and t-shirt still from the gym. What must it have looked like, winter weather a dude in summer gear trying to push a trans am up a slope in the dark. Anyway a car comes up the road, and nicely gives me a hand pushing. Then a neighbor comes out also giving a push. we turn the car round, aiming for the drive. Back wheels in, and then it bottoms out, giving it a few good shoves it finally goes in, scraping like a good one. Good job I put down the planks of wood or we would have no chance getting it in. Both the additions pushers leave. I now need to get the car back into the garage, the driver way is relatively flat. It is tight getting the car into the garage, the ground is damp and slippery. The front wheels get caught in a rut, I'm tring to rock the car on my own get get it to budge, using the wall with one hand, holding the sail panel of the car, and one leg pushing on the floor the other pulling on the wall. So now I'm star shaped and the car is barely budging,using all my strength while changing various shades of red and purple (good job its dark) This was better than a gym workout.
Finally get the car tucked up in the garage. I rocked the car in gear in case the started was stuck. Tried to jump start it from the fiesta just in case the battery was iffy. As I have noticed recently that the battery has trouble turning the engine, it would be slow and then speed up and fire.
Well no luck, starter just clicks. So the engine has too much friction to turn over. So I need to try and turn the engine by hand with a large breaker bar on the bottom pulley wheel. I'll take off both the rocker covers to inspect. Its likely to be a heads off job.
Wont have time tonight, so this is a weekend job.
