Depends weather the teeth of the puller will get behind it. There is a multi choice of pullers in a garage in Wales lol.
Pop round for a cuppa, I'll pop the kettle on.Depends weather the teeth of the puller will get behind it. There is a multi choice of pullers in a garage in Wales lol.![]()
No need to pop round. My 150mm puller couldn't get behind, however my 100mm one could. Having that chain on there actually helped with that puller.Pop round for a cuppa, I'll pop the kettle on.
No chain guides. 98 and 99 cars had them 2000 didn't. There are no threaded holes in that block, they were later re-introduced in later engines. I did consider drilling holes and tapping them to install guides from another year.Was there some chain guilds to go on as well they might be on I can see them not got my glasses on lol.![]()
Yes considered doing that too, or stripping off the old stuff. I got this from a 'proper' paint place. They said it is for aluminium engine block. Very disappointed that it's flaking off, wish I left it bare metal. A lot of the front cover is hidden luckily.Might have painted the cover while it was off?
Thanks, yes metal gaskets before. No leaks before.Looks like the pump had the metal gaskets fitted. What was being used when you took the pump off? If you had no issues I would use like for like.
They are in Mexicanwhat do the destructions say in the pack???????
