AmericanThunder
Super Moderator
So if you can't avoid filling up with regular unleaded as opposed to super unleaded you would expect to see much more knock recorded and see more timing being pulled?
The LT1 was iron block with aluminum heads and featured a reverse flow cooling system. This meant that the heads got the coolest coolant allowing a more agressive timing curve. Wonder why GM did away with that on the LS motors?
