Many years ago I installed a heads and cam kit. The cam is a 226/226, the standard cam was about a 198/200. Well a few weeks ago I was thinking that the valves open earlier, and there is an overlap between intake and exhast.
However with this change in valve events I havn't changed the injection timing. I've changed spaprk events and fueling, but not when the injector fires. I've never seen talk of this feature on forums so I thought I'd bring it up on the LS!tech forum, http://ls1tech.com/forums/pcm-diagnostics-tuning/1427353-anyone-played-injector-timing.html
Basically with this overlap in valve events, some of the raw fuel can get sucked out into the exhaust. So if the injection fired a little later after the exaust valve has closed then it can burn more of the fuel I squirt in.
