They have arrived. Will make the car sit 1.5 inches higher at the rear. The diameter looks small. Its ment for my car. Sit on the axle, springs locate on top.
Excited to go and try them.
Yes its the angle of the picture, the cup of the sping extender fits snigly onto the raised bit on the axle. I had to disconnect the shock at the bottom. to give me enough room to get the extender in there. Was tough to sqeeze the spring to position. Usually the spring will fall out with no shocks connected, but with this extender it is tough. So if anything the spring will find it harder to come out than standard.The ride height dose look better. But to me from pictures the set up just dosnt look right might angle pictures go over a pothole or a sleeping policeman speed bump it could jump of. Or out of set up..
I know what you mean, in some photos it looks like they are sticking out.I may be wrong but I thought tyres/wheels had to be within the arches for MOT purposes.
Yeah I have some stuff. As I was doing up the end links the support for them is showing signs of rust. I'll take bits off to treat and do bits underneath too.its good you found something else wrong when working on car,
need to put some rust treatment in some areas you can see the rust coming through the stuff that neutralises the rust not just covers it,
