For some time I have been running no cats on the car. I have long tube headers, then a short straight through pupe, then into the y-pipe, 4 inch down the car to the back box.
The short straight pipe had the wideband sensor in it. I have installed the sensor next ot he O2 sensor in the driver side long tube header. So its at a point now where I could remove the straight pipe and install the cat as the cat is the same length as the straight pipe, designed to swap in/out.
Old picture showing the red rin for the clamp. Green is the the straight through pipe.
However the sleve that joing the straight pipe to the Y pipe is a 3 inch sleeve with a little step in it. I tried removing this, but the bolts are stick solid, not tried heat. I see its cheap enough to buy new. I'll cut the old off and pop on new with the cats.
Replacement sleeve clamps have arrived.
I'll post more pictures during the install. Perhaps a job for this weekend?...
The cats to go on, Thes will change the exhaust note not so raspey, and not like a gatling gun when getting on it at 2k rpm.
