Removing ABS from 4th Gen Trans-Am
As most of you know I have had a bit of rear axle issues. Document in the blog:- http://www.solent-renegades.co.uk/entries/51-rumble-rear
It started as a rumble at the read, as the diff decided to loose a retainer clip, got munched up in the gears, so now need a new ring and pinion, and where there was soo much swaft in there, new diff, bearings etc... Not wanting to do the job myself again. I looked at either repairing the axle I have to upgrading to a super duper one. Which ended up with the discussion of 12bolt or S60, http://www.solent-renegades.co.uk/general-discussion/16579-s60-vs-12bolt.html even sonsidered shippinf in a complete axel from the states. around £3k for S60, or £1100 to repair what I have
Due to funds really I had to go the repair option. I contacted Hauser Racing to do this job. They can order in all the parts, just give them my old axle and it comes back complete.
So thats the summary of where I am.
The car has 3 channel ABS, meaning there is a speed sensor on the center of the axle, there is a reluctor wheel on the outer edge of the diff, this was soo badly damaged it couldn't go on the new diff. So Hauser has been on the search for a replacement for over a week, they just can't get hold of one, I've had a search too with no luck.
So the issue is, can I run the car without this sensor?. This sensor is used by the ABS system. This started the discussion in this thread:- http://www.solent-renegades.co.uk/g...you-done-your-vehicle-today-28.html#post46421, removal of ABS is probably the way to go.
There is a kit for the Trans-Am from this page :- SJM Manufacturing, Inc. (724) 478-5580
So whats in the kit.....
Each kit includes:
- Fittings/assemblies necessary for all connections
- Adjustable Wilwood Proportioning Valve with preassembled fittings
- Pre-formed lines
- Proportioning Valve mounting kit
- Complete Instructions including pictorials and schematics.
Options:
- Re-buildable Hurst-style Solenoid with Electrical kit
* Hurst-style Solenoid
* Micro Toggle Master Switch
* Micro Momentary Control Switch
* Remote LED
* Installation Wire
* Fuse with holder
* Electrical connectors
- Double Flare Tool Kit (modified for metric/standard brake lines)
- Upgrade to shifter switch control for manual transmission vehicles
Benefits:
ABS Kit:
- Deleted ABS controller and bracket
- Removes typically 14-16lbs of weight from the engine bay
- Increased engine bay air flow
- Eliminates front/rear mixed tire diameter dilemmas associated with ABS
- Brake bleeding simplified
- Simplifies turbocharger and supercharger setups
- Cleaner appearance of engine bay
- Allows easier access to engine and enginer components
Line Lock Kit:
- Exclusive two stage switched circuitry
-Visual feedback of circuit activity via remote mount LED indicator
-Installation does not impede with supercharger/turbo kits
- Easy install. Lines, valve and fittings come pre-assembled; brake sealant is not needed for connections
-No modification necessary to existing brake lines
-Solenoid location mounted away from heat sources for years of trouble free operation
-Micro controls can be easily hidden within the interior for stock/stealthy appearance
-Professional installed appearance
-V6 and V8 compatible
-ABS/TCS compatible. Will not interfere with normal ABS/TCS operation when not in use
Note: No modification is necessary to existing brake lines for a direct bolt on kit. No Teflon tape required; fittings come pre-assembled!
[/TR]
[/TABLE]
I was toying with the idea of line lock some time ago. So with this kit resolving the issue of the lack or rear speed sensor, brakes still working well and line lock feature. All should be good to go :)
Now to get this done before wheels day. Hoping the axle will be back soon.
You can begin the conversion on the lines and fitting of the prop valve and LL without the axle.
If the kit arrives quickly you can get it done ASAP
I think the Axle will be ready before the ABS kit arrives, mind you the luck I have been having it may not.
The kit should be shipped out this evening. Its coming USPS. so regular mail could take over a week. I have the tracking number. :)
Uh oh - USPS turns into Parcelfarce this end :( :( :(
Yeah, I was hoping the first S wasn't in USPS. It could take some time.
did you know u can put the US tracking number in Parcelfarce's website which will give you the GB tracking number ;)
Yes, and if you track it to customs in the UK you can phone and pay instead of waiting for them to notify you. Takes several days out of the process.
Only once it's showing "a/w payment of charges" though. Don't wait for the Parcelforce notification letter to come through ;)
Tracking info not showing progress yet, going by the status, I'm not sure its even been picked up.
DATE & TIME
STATUS OF ITEM
LOCATION
March 17, 2015
Pre-Shipment Info Sent to USPS
oooh, there has been an update
DATE & TIME
STATUS OF ITEM
LOCATION
March 19, 2015 , 11:38 am
Picked Up
APOLLO, PA 15613
Whoop whoop! Keep an eye on parcelfarce website too now :)
oooh, another update... how exciting!
March 19, 2015 , 4:38 pm
Departed Post Office
APOLLO, PA 15613
Pennsylvania, hmmm, now will it go to Maine or Nashville for its Atlantic crossing?
or maybe neither - USPS might use another route!!
I've obviously spent far too long watching my parts go from door to door over the years! :nerd:
Could also go via Chicago too :)
Still in PA
March 19, 2015 , 11:02 pm
Arrived at USPS Origin Facility
WARRENDALE, PA 15086
Its gone 38 miles the wrong way. Perhaps its taking the route over China? lol, or perhaps on its way to Pittsburgh Airport, only 28 miles away by road.
Tracking is:- https://tools.usps.com/go/TrackConfirmAction!input.action?tLabels=LZ314629465US incase anyone else wanted to enjoy the fun tracking this. I was surprised how much tracking info there is on USPS. It used to be Picked up, at customs facility or delivered, were the only things I ever saw.
Just phoned Hauser racing, the axle will be ready this afternoon. So I will be leaving work at 12.30ish. They said it should be ready by about 4, or 4.30pm. Yay, should get that bolted in at the weekend. :)
