This is a replica of the awesome 1967 Chevy Impala as driven by Sam and Dean Winchester in American TV series "Supernatural". Its one of only a few cars in the world that I feel looks better as a four door than the 2-door model. This car is a proper nasty looking American muscle car and looks extremely menacing on the road. It has a great stance and sounds incredible with its roaring V8. It has proper brand new 15 Cragar Chrome rims with deep dish on the rear and large BF Goodrich tyres to make it sit up and beg. <br />
<br />
The interior is a golden tan colour and has a new headcloth and fairly new carpet. All gauges work and both bench seats are good except for one small tear in the rear. Car has just been MOTd last month and passed first time. Chrome is all good, not show quality but still looks great. <br />
The paint on the car was done to give it a nastier look so a little flat with several imperfections like driver quality but not show. Although it was taken to the tin less than a year ago the car in the TV series was supposed to be a little rough around the edges so the previous owner wanted to reflect this in its appearance. Having said this it wouldn t take much money to get it up to show quality. It would certainly be worth doing if you re not a Supernatural fan and want perfection but it looks great as it is.<br />
The car is extremely solid and started its life out as a California Factory A/C 396/th400/12 bolt Caprice (higher Spec Impala). It was purchased by a Major in the Army in California and resided there until the late 80s, when it was brought to Texas. Actual miles on the frame and body are just over 99,000. The floor pans and chassis on the car are like new even the MOT guys were amazed at how clean and solid it is.<br />
The car was stripped down and had all the heavy lifting done mechanically:<br />
Engine:<br />
*All machine work done by Billy Graham Performance Machine of Manhattan KS*<br />
010 GM 350 block, bored .030, align honed, flat decked, ARP bolts throughout<br />
Crank ground .010/.001<br />
Chamfered oiling holes<br />
Speed Pro HT-16 Pistons with Engine Pro Racing chromoly ring pack (1/16, 1/16th, 3/16th rings)<br />
GM X code rods w/ ARP bolts<br />
Balanced rotating assembly<br />
GM 350/350 hydraulic cam grind<br />
Erson 1.6 roller rockers<br />
GM 882 heads decked .010 to flat, 3 angle competition valve job, light porting, pinned studs, cam matched valve springs<br />
Mellings Oil pump w/ bolt on pickup screen<br />
Weiand dual plane intake<br />
New 600cfm holley carb w/ electronic choke<br />
HEI distributor blue printed with Accel module and coil<br />
Double roller timing chain<br />
Summit G9001 Headers <br />
Billet Specialties billet air cleaner lid and valve covers<br />
Billet PS and Alternator brackets<br />
ARP head, rod and main bolts<br />
Sealed power bearings<br />
New matched harmonic balancer<br />
Factory timing chain cover<br />
The oil pan is a stock 5 qt pan; the motor has 5-30 oil in it and uses a standard sbc oil filter<br />
This oil pan gasket is the THICK LIP gasket<br />
2 piece rear main gasket, standard 350 fel pro head gaskets, standard intake gaskets<br />
<br />
The engine is 9.3:1 compression (pump gas friendly; run Premium gas) and has good compression across all cylinders, less than 500 miles since it was built. Great idle, fires fast and runs well. Very street friendly motor. Makes a little more than 360 hp/ 380 ft lbs.<br />
<br />
Transmission:<br />
1967 TH400 freshened up with master rebuild kit (seals, clutches, etc)<br />
new Torque Convertor (2200 stall speed)<br />
raybestos clutches <br />
New rear band<br />
B&M shift Kit<br />
New vacuum modular <br />
*This is the OLD style filter transmission, early 1967 and older style*<br />
Transmission has synthetic Dextron 4 in it<br />
<br />
<br />
The following components have also been replaced:<br />
Battery Tray<br />
Power steering Pump<br />
Power Steering lines<br />
Rag Joint<br />
Inner and outer tie rod ends<br />
Rubber suspension bumpers<br />
Upper and lower ball joints<br />
Wheel bearings<br />
Front and rear springs<br />
Front and rear shocks<br />
Sway bar end links and bushings<br />
All bushings in the front and rear suspensions<br />
Rear and Mid Parking brake cables<br />
All brake hardware<br />
Rubber Brake hoses<br />
Wheel cylinders<br />
Brake pads<br />
Master cylinder<br />
Brake power booster<br />
Drums have been turned recently, have good life left in them<br />
Gas tank, gas cap and sending unit <br />
Washer fluid tank<br />
Rear U joint<br />
Alternator<br />
Radiator and cap<br />
Starter<br />
Water pump<br />
Fuel Pump<br />
Rubber fuel Lines<br />
Transmission Mount<br />
Engine Mounts (Post 1968 locking style Poly Mounts)<br />
Belts<br />
Hoses<br />
Front hood trim and eyebrow trim<br />
Flexplate<br />
Hood trim<br />
Eyebrow trim<br />
Sidebrow trim<br />
Taillight lenses<br />
Headlights<br />
Turn signal lenses<br />
Corner light lenses<br />
<br />
<br />
The car has had a new front end hardware kit installed in it. In addition virtually every nut and bolt on the underside is new. Nearly everything was replaced with Gold zinc plated hardware. This car is a true 4 link car as it was a factory Big Block car, and it has had impala bumper ends and taillight lenses installed. Most of the moldings and the chrome are driver quality, a few pieces are better than driver quality. It is a factory A/C, corner lights, and bumper guard car. The dash is not cracked, and the gauge cluster is in good shape.<br />
<br />
the car also had an internal regulator conversion done, allowing for a more reliable late model alternator. The alternator is for a 1984 trans am with an LG4 305 in it. The Power steering pump is for a 1974 Camaro with a 350 in it. <br />
<br />
The rear end was just serviced. Has factory highway gears (3.08) and cruises well at 80 mph. Use 80/90w<br />
<br />
The heat and a/c are not hooked up, but I will include all components that I have for the car. The trunk will be full of ALL the odds and ends I have for the car. <br />
<br />
<br />
<br />
<br />
Date written: 16-Jan-2017
Price: £25000 Or near offer
