Added a clamp to the back of the intake to hold in that MAP sensor. Didn't come with a clamp, also only had a blind hole that needed drilling as not all applications need it.
Test printed in cheap material to make sure no oddities. Was something on the bottom part where it was too thin. Test print also good to see size and check fitment. The bottom bit would cost over Ā£25 to print in high temperature material. Test printing around Ā£5.
Happy with the top bit, no further changes to be made. It's come out really well. Happy with that.
See int he vlalled there is a black circle, there is another further along. Under these are little microphones, called Knock sensors, they detect detonation of the engine and retart the timing if need be. These are the originals, 25 years old, 200k miles old. They can become sensative over time, also there was an altertation after 2000, so in 2001 and 2002 were alterations to avoid fals knock. Now I do see diring logging I do get some knock detected, but I do/did have the exhaust touching the body at time. Anyway I'll fit new ones., its about time.
They just screw into a thread on the block. easy to swap out. Providing nothing breaks on the wiring, or the plastic.
Atleast they are not made in China. These are Mexican.
Injectors won't fit the new intake, they are too fat.
Furl rails have the wrong fixings spacing. Apparently the intake is based on that LS2 which is slightly different to the LS1. It's only fuel rails. Heads for LS1, LS2 and LS6 are all identical. Injector length may be an issue too. Working though forums on that one.
The LSXR intake is based more on the LS2. The fixing hold are slightly different for the fuel rails. This pucture shows additional hole. Almost brought this kit, but the fuel rails look verymuch the same apart from the fixing holes. So I'd really only be buting it for the fixing brackets. I could probably make something brom a bit of aluminum angle.
Next problem was the injector fitment, the LS2 fuel injectors are shorter(at $600+ I'd rather reused my LS1 ones). The length I can take up with custom made brackets(no I'm not 3D printing it, if vibration and heat does something, the 3bar of pressure with surely help it break free) using aluminum and screws.
My injector are fat, I can dremel the orifice whre it fouls on the intake. However it seems my bottom seal on the injector is too small (LS2 injectors have a thicker o-ring). We have a local company called Flowseal, they are great for this kind of thing. I'll pop along on Monday and see what they have. In the meantime I have other things to work on.
The thinner injectors should sit lower. These are available at Summit racing. Ordered 50lb/hr injectors and the fuel rail bracket as these are LS2 injectors they are shorted but the intake it really ment for LS2 stuff including the spacing of the fixings of the fuel rail.
Also my 2 pin connectors are called EV1, I will need to convert to EV6.
With the delay in shipping. I'm not aiming to get these mods done for Wheels Day 18th April, but rather put the old stuff back on for the show and do these modifications afterwards.
Payment taken, The dollar price is around 10% higher than GBP. However get 20% slapped on by our taxes. So that will be Ā£160 to get it through customs.
New injectors ordered. Really impressed with the info that Deatschwerks injectors have.
In the ECU there are manay table to do with injectors, like flow rate at divverent voltages vs manifold pressures. They give you all this info in a spreadsheet.
Flow rate
Minimum pulse widths.
and Short Pulse Adder
This gave me a great fuzzy feeling. Brought these from Summit racing, may be here this week. Seeing all this information gave me great confidence in the product.
Even brought up my ECU tuning stuff, and got it programmed in ready
Also last night done a bit of air intake drawing. Its getting there. Mainly working on the part around the radiator support.
Order has been with summit for 27 hours, still marked at "waiting to be despeatched". I have contacted them and they did come back quick. They are not waiting on anything from me. its to so with shipping. for customs they has to label everything with the place or origin. They are waiting to find out where the injectors were made.
The manufacturer is Oklahoma USA, just a bit north of the Summit Racing offces, but I guess they need official paperwork to say that. More delays.
