Well last Sunday I was driving on the motorway, and under light load there was an odd noise coming from the rear. A bit like metal on metal,. it was also speed dependant. When coasting there is no noise at all.
Got the car in the air Tuesday evening. Checked the diff oil, there is oil present and couldn't see any metal in the oil. There is a big magnet on the dif, so I guess most metal particles will be on that. I suspect its a bolt on the ring gear that may be loose and rubbing on something, its that sort of sound. The pinion feels tight. It could also be wheels bearings.
So Saturday I will take off the diff plate and take a look inside. I have some new oil to pop in there from Opie Oils.
