So sorry for the geographical error! If ordered before the end of the week I might be able to get free shipping to Florida,(not promising but willing to try).
The S60 gear ratios available are 3.54, 3.73, 4.10, 4.30 and up. The 3.91 is not available.
Unless You could find a used set of brake backing plates stateside to send to Strange the axles and bearings would need intalled when Your S60 arrived in the UK. It is not a difficult task but does require a bearing press.
Pricing is $2299.00 for the S60 with the S-Trac or Tru Trac posi unit. The Strac is mfg by Strange and is 8 lbs lighter and is the one I suggest using.
Your driveshaft will need shortened and a conversion u-joint used or replaced.
Strange offers a ready for paint and installation 3" chromemoly tubed driveshaft electronically balanced with 1350 u-joints and trans slip yoke for $318.00.
If I can answer any more questions please let Me know.
Thank You,
Carl
