Silver looks nice, but I do like the Orange bird on a red car.
Yes it will stay red weather it stay's the same red or slightly darker as red at the moment has faided see what they get of vin number
are yes same price as firebirecentral as phenix graphics like the gold on phenix but silver on firebird but when you google red TA to get better ideal silver looks better on the red
VIN doesn't contain colour data.
If the RPO codes sticker is in tact that will. Door jam is most likely location, unless you have the build sheet?
And agree with Dan on the bird choice.
these are my choices so far but not DANS CHOICE SORRY
Out if those two - gold looks better IMO :)
I prefer the one Dan posted too he he ;)
I think you'll find majority of the companies selling the graphics get them from Phoenix graphics anyway :)
I think the one dan likes is for 75-76 which I must admit I like as well.
Must admit can'tmake my mind up weather gold or silver but looking here gold is coming out best at the moment,
AT will look see if i can find any numbers
1978-80 Trans Am Decals and Stripe Ki
Think it's going to be silver but will wait till i have spoken to body shop,
sorted power steering hose replaced no more leaks nice, and replaced rubber hose from radiator to gearbox as this was metal pipe that had two rubber hoses on replaced as well as they looked like they were weeping,
Not surprised that they weeped. There is some pressure on the trans cooler lines.
Right, in the possess of putting in reverse sensor,s found a lot of bad wiring so an extra job to do now to sort this out found the green wire for the reverse circuit that was fun it wasn't giving me 12volts found the switych on steering coloum not connected properly so fun fitting back in place but also have no reverse lights so question do i add extra reverse light ie a led strip under bumper or do i convert the lamp sockets? or not and just have sensor's?
[/URL][/IMG]
I think the LEd kit may be good for side lights, but I have a feeling you wont be able to see much with them while reversing. Usually side lights a 5W which these are for replacing, a reverse bulb is 21W, so you would need 4 of these per side, so 8 along the bumper to get enough light as a pair of reverse bulbs. It would look awful. Well that's what I think anyway.
I'd prefer to convert the lamp sockets, well keep it in the rear light cluster, is there no socket there for it at the moment?
The car dosn't have reversing lights the green wire has been cut, i beleave from the lights i have the two (one etherside of fuel flap were the reverse but have since been changed to indicator lights and all other lights are rear lights + with brake lights ie 3 rear lights per side and two brake lights per side as can be seen from picture the wiring has been played with badly so i have to sort that and would like to put reverse lights in weather it be a led unit under bumber or intergrate in to light cluster but my lights are smoked type all the lights work ie rear lights brake lights indicators,
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
