Ooh, shiney. How does it connect? King lead or tranny?
Looks the part though.
It's a direct replacement so using all same wiring apart from new feed to clock as there is two type of membanes on back of dash unit, result :thumb:
Lighter unit bit more fun as refitted new unit and blu fuse tried again blu again so tried it with phone charger all ok so cig lighter unit faulty as well as main casing but as i don't smoke won't worry it works for charger ,
I've worked with a few service engineers, and learned if a fuse blows and then blows again, then you need a bigger fuse. ound:
See you finally got a better bench!!!
Quote Originally Posted by Chriswrx123 View Post
Reckon the job suited the saleen actually!
Doh!:doh: thought the can of red oxide had the wrong lable on it or am i dislexic .
