Camaro Progress.....
Yes I think I was lucky ordering a starter motor Thursday lunch time and the part was in LA (furthest side of the States) came into Fareham depot Saturday morning, but they don't deliver Saturdays, so I popped down there to see if I could collect, and I could. I was very lucky with that order. Got it fitted ready for the Southampton Bargate car show.
never had any issue with Rockauto before but considering their shipping prices are high they should deliver better service than that!
There's no shows to prep for that's not so bad.....but I'll miss out on the 10 days retest so will more than likely have to pay full whack again....and have Simon come over twice on his weekends off to give us a hand.
Quite disappointed with them this time around.
That's not fair Sarah! I have never known them take that long before either :(
Currently sat in the boot and removing everything to get the carpet pulled up ready for welding this weekend :)
[/IMG]
Two bits of good news......all this tain we've had isn't all bad.....it's proved the sealant job Dan did on my windscreen has worked!! There is no signs of any water in the driver's footwell :)
Aaaaaand......... The important patlrt of my order from Rockauto has arrived!!!!! So I now have rear brake cylinders and shoes in hand, just the strings and levers to wait for (they've been with Yodel in London for four days)
Massive sigh of relief!!!
Haha, does look a little dodgy....but it a screwdriver and box of screws :)
Yay Sarah - good news :)
Have you tried ringing Yodel to find out why it's still sat there?
yodal have a tracking system and text service , sidenote will it make good wood next weekend?????????????
Been to Pro Parts this morning to pick up a new flasher unit, hoping this would sort out the lack of left indication.....thank fully it worked!!
[/IMG]
Now onto the rear fog....
Guess what numpty left the keys in the ignition. Only has one set of door keys. Doh. Easy access from the boot.
Don't loose those keys , THINK you would be hand drawn and quatered if you did lol
Whoops!!! What a numpty! I will not be doing that again lol
So.....the rear fog light is now rewired and working. Dan drilled a hole in the bodywork, behind the rear light to feed the new wiring through and hey presto....one legal rear fog!!!
All ready to go......
[/IMG]
Dan drilling the hole for the new wiring....
[/IMG]
New wiring all in place and now working :)
[/IMG]
Shame on you Dan did you not fit a grommet before putting cable ? can't make it out in picture
you got no battery powered tools ??????????????????????????
Fresh out of grommets, although did de-burr the hole. I wanted to pop in a grommet to make a good job of it . I do have a battery drill but in the loft where I have been doing some boards up there. I needed to get the extention lead out as mowed the lawn too.
FINALLY my other brake parts have arrived!!!
Note the date Yodel have on their packing when it arrived with them......they are getting one big ask complaint!!
[/IMG]
Yay, more bits. Wont be long now till it fitted and passing the MOT.
Yay - good news.
Be interested to know what their reply to the complaint is :)
Well, got some bad news......
The hole that was by my seater actually goes all the way to the front footwell. So I have no choice but to order a new floor pan for her :(
Photos.....
What it first looked like.....not too bad looking? Welder and steel all ready, then we started digging....
[/IMG]
And this is what we found :(
[/IMG]
[/IMG]
[/IMG]
So with us not being able to do much with the bodywork we turned to the brakes. And this is the state they were in......
[/IMG]
Had everything for this but one hiccup has stopped us doing any more until next weekend. The levers inside the rear brakes are attached to each other with a rivet. We did not have a small enough rounded hammer to put these together. So.....Simon (who's helping us out) will be getting a bearing from his garage Monday so we can carry on next weekend.
So I guess the Camaro will be off the road for a little while longer. Quite gutted but want everything repaired on her properly, and seeing as I intend in keeping her for a long time I've got make sure it's all sorted properly :)
