About $1300, which will be close to £'s after import tax.
Thanks, I may take you up on that offer. Thanksif you want use of an engine hoist to remove the sump i have one
I have the remains of the old bolt, and new bolts are coming. I may be able to estimate how much if any of the bolt may be protruding.
I may have to use some form of 'easy out' to get the remains out if its recessed. Failing that, drill into it, tap and helicoil hole, I really hope it doesn't go down that route. We shall see.
Hopefully bolt was on it's way out and not bottom out on thread when being done up , those are long bolts not seen sump bolts like that before,
Doh that's for boilers not cars. Surprised they were open all builder murchant closed like all the shops
I was wiring up at work last week and CEF, TLC and Screwfix were open, but with precautions in placeDoh that's for boilers not cars. Surprised they were open all builder murchant closed like all the shops
I've found leaks to be sealed with sealant before where just a gasket wouldn't.it's an old catalogue I got about a month ago, just flicking through it after recovering from the fast walk.
Correct. It has worked for me with imperfect rocker covers and pressed steel sumps.If a gasket can’t seal as designed there is usually a problem like a deformed or warped surface.
I was watching 'How Its Made' type program where they were aeembling a C7 engine, they applied a great bead of sealant on the sump. I know its a newer generation, and perhaps they had no gasket. The GM book for the transAm says do not use sealent, yet we see them using it in their manufacturing plant.
I only posted as I saw that odd picrture of sealent. I still need to remove my sump and inspect.
