Well some time ago, back around September 2016 I had a broken rocker. Had to borrow tools to take of the rocker covers at a show in Portchester precinct. There was a broken rocker, took off 2 pairs. Ran the car home on 6 cylinders, it worked quite well. Got some new rockers and pushrods to see if that would cure the problem as the next thing would be to change the lifters which is heads off.
[video=youtube_share;wFnq6FsOYGw]https://youtu.be/wFnq6FsOYGw[/video]
Very rocky, sounds like a bent push rod. Found the loose one, second cylinder back on the drivers side. The push rod is fine, which leave a lifter or Cam issue. So heads off time.
Started today, just taking out the radiator, Will be carrying on at 8am Saturday.
As radiator out, fluid still dripping so will popping in a water catcher.
It's home for the night.
