Are you having a huge single door or two with a divider? Also, are you lining the garage and insulating ( I may have missed earlier posts about this.) And, you might want to consider a de-hufidifier with an externanal drain so it can run 24-7. Before I had my wood garage built I was extracting 5 litres a day!
Having just one door 4.7m wide. I was thinking that way I could park in the middle and have all the doors wide open and walk around it, or park two cars in there.
The walls will have thermolite blocks on the inside with a 2 inch cavity, there will be insulation in the gap with an air gap too.
Dehumidifyer is a good idea, that 5 liters is a lot each day. I can put in an external drain.
It was an old brick built garage with an up and over door. Barely room for the 68 inside. I'm not aware of a water course running underneath, not a problem now with the insulated wood build.
Tried it yet with both cars in garage or a car over pit to make sure all ok don't forget garage will be just over a foot 12 to 18 inches smaller once the internal wall goes in.
Done some sketches in 3D to get an idea of size. The garage has gone as big as possible taking into account boundaries and not loosing too much garden. The depth of the garage measures 6.3 meters, the width is around 7 meters on the internal walls. We have used tap measures to get an idea of the car over the pit. We wont be able to open the car doors wide with 2 cars in there, but then we couldn't really go any bigger, so I'll have to make the most of what space I have. The builder says the garage is massive, biggest one he has done, he has done doubles before. If I need to take a door off the car for any reason, I can open it fully on the work bench side, or could just have one car in there.
The builder say says the Steel Man will be coming today, I kept thinking what does he look like, we know what Iron Man looks likes, have they brought out a new character?
Chatted to the garage floor people, they called me for a chat, and emailed me though a quote for the same ones I have a sample for and for ones which can handle a jack and axle stands. It comes with ramp parts too, also you can have a logo printed on the tiles.
Thinking of getting a couple of tiles printed, perhaps a Sponge bob one and a modern Pontiac logo.
