Got a bit of work done to the Nova, I was planning on taking out the starter motor and giving that a once over, but my Dad must have taken his tools with him on holiday (I must get myself an imperial socket and spanner set) so I had to do some other things.
I wanted to stop oil getting in my air cleaner and crudding up the filter, so I removed the passenger side rocker cover and drilled out the hole to 1 1/4" so that my Edelbrock breather would fit. I managed to fit it while retaining the original baffles. For the drivers side, I do have the matching Edelbrock breather with a pipe fitting, so that it replaces the PCV valve, but I don't know if this would be the best solution, or if just fitting a new PCV valve would be better?
While the air cleaner box was off, I did something I should have done a long time ago...disconnected the EGR valve. It's still on the car, but is no longer functional (always off). It will be completely removed when I get the new inlet manifold.
While all the air cleaner stuff was out the way, I took the time to check the dizzy cap and it was all good, only a little bit of normal crud. I also tidied up the spark plug leads route. I was going to check the plugs gaps, but I need to get the smaller size spark plug spanner, will do that soon as it's the only part of the ignition system I've not checked or renewed.
After that, I turned my attention to the immobiliser. A few months ago we found a horn hidden in the engine bay which had similar wiring to the immobiliser, but was not working. I traced the wires and got it working (when the immobiliser is on, if the bonnet is opened it sounds), but then had issues when I tried to start the car, so I'll have to investigate the wiring further, but will have it all working soon.
Next jobs for the weekend are...
Starter motor
Spark Plugs
Immobiliser Wiring
PCV or Breather
