Darren
Yeah, always something to do.
Been looking into it more and I may fit an oil catch can after the PCV. I say PCV as I'm still in 2 minds as to if I should remove it or not. I've found out that PCV valves were only fitted to the SBC from 1968, and other than all the emmissions rubbish and the compression ratio, I cant see the engine changing that much in the 4-5 years til mine was built. I'm not going to do anything silly like block off the ventilation to the crank case, but I have something that looks a lot prettier to sit on top the rocker cover (http://www.edelbrock.com/automotive_new/mc/accessories/br_chrome.shtml #4410) which'll then go to the catch can, and then back to the port under the carb. The only thing stopping me is that I've heard people have problems at idle when they removed the PCV (though this was not with a 350 chevy, but an ECU'd honda). But then again, a mini's crank case breather comes out a back plate on the engine and then straight into the carb, so would doing that on the chevy be bad?
