Checked my dip-stick yesterday morning.
It's about halfway up the cross hatchings, (was at the top at Beaulieu) drop stick is a little hard to read as there is always a streak of oil up one side, but it's solid from halfway up the cross hatchings, so going by that.
As it's been nice weather I have been leaving card under the car as soon as I park up, and no oil drops at all when I checked the oil yesterday morning. So it would appear I am on top of the leak.
Club last night. getting more confident with the loud pedal. The was a BWM hairdressers car going around the roundabout before joining the motorway, he/she had no lane discipline at all in the right hand lane of the roundabout came off in the left lane on the slip road and then over to the right again. So I just stayed in the left waited for him to join the motorway then I was off. Malc was already on the motorway as coming down from horndean, so also the ideal time to accelerate a bit more than usual. He saw smoke, and smelt oil. Which was good to know.
Went for a cruise around portsmouth, great to go around old portsmouth again. On the way home I gave I even more beans, it was getting dark by then, 1500rpm on the motorway, then foot to the floor to about 2300 rpm. Torque felt pretty good. Came off the motorway, and gave it some throttle down the dual carrigeway, picked up well not missing a beat. Wanted to do it as partly wanted to know what it felt like, and second to force oil out/bed in rings. As soon as I got home, card was under the car waiting.
Checked card and oil this morning. No drips on the card.
Oil is down a little bit.
Spoke to Tim at Opie over private message yesterday, as it is a stroker the conclusion is 5w-30 to start with, but if it uses a lot of oil, switch to a 5w-40 next time.
So I believe the 3-4 litre leak to Brandshatch and back, was cured by a loose oil filter(I only done it hand tight and not the extra 3/4 turn)
The oil filters was not the only leak, as cam position sensor was still giving off a couple of drip after driving. Sensor taken out, cleaned up and put back in. (at present does not appear to be leaking, if it does I have new rubbers for it)
With card going under the car right after stopping this should prove for any leaks, as if it is leaking when driving then there should be a few drips hanging on ready to drip onto my card, card being there all night. Real tests is getting underneath at the weekend and check.
So if leaks sorted, then I'm burning it. Rings probably still need bedding in. So with more hard driving that should happen, and keep an eye on level.
As for US oil, I would be tempted to use it if available, however if not available, then perhaps I use UK 5w30 and change more often. I wonder if Opie would stock the US version, I guess that depends on if there is a requirement from many people for it.
Hi Dan
Keep an eye on the level as hopefully the consumption will slow as the rings bed in, but if it keeps going down at that rate, go for a 5w-40.
Cheers
Tim
