It's all working progress. I may find once the ECU earth is looking good there will be another area to improve on. Was hoping to get some time on it tonight, but some work has come up that will consume my evenings until the weekend.
Absolutely Dan...if the oil pressure switch circuit was causing the ECU to inhibit fuel injection, there would be no waveform accross the injectors, not a low amplitude one. I'd say don't waste your time looking for fuel in the cylinders, you've already proved that there isn't any.If I pull the injector it can't fire anything as no fuel can be connected to it.
The oil pressure sender dosn't appear to be causing any issues. There is 12V on the injector, the other side is pulled to ground from the ECU which isn't reaching true ground, its about 4 volts off, indicating a bad earth somewhere.Still searching for that earth, which is why my next step is to check the ECU earth while cranking. As earth are saying zero ohms, but this is when there is no load, pretty sure there is a rotton one when pulling current.
Yes very possible. The ECU has 2 switched outputs for the injectors, one for each side. When looking at the volts it's switching the neg side seeing 8 volts across the injector. It dosn't appear to be switching complely to ground. Once ECU ground checked/sorted and still not working the next step is checking for a failed component in the ECU. It's old tech nice big components. Should be easy to put in a modern MOSFET or something similar, I actually have tubes of them laying about in the TO220 package.You could ultimately have a fault with the fuel injection firing side of the ECU. If so, it might be worth having a crack at repairing it as it's not overly complicated. I have been looking at various injector switching schematics on the web. I couldn't find one for the Camaro (and I'm guessing the wiring diagram in the manual probably doesn't show the inside of the ECU anyway?).
Firing the injectors by grounding them seems to be a standard way of doing it. Most systems appear to have a low value resistor between the switching transistor and earth, presumably to limit the current through the transistor. If the resistor was to go O/C or fail high, this would stop the injector being pulled to ground and from firing. Some system have separate resistors for each transistor and it would obviously be very unlikely for all 6 to fail. But some have one common resistor in the ground line for all of the transistors. If the Camaro's ECU is like that it may be something to consider.
Yes good valid points and things to test. What I have found so far is the ECU is trying to switch to ground on the 2 injector control pins, but it dosn't quite make it like its not strong enough to do so. it gets about 4 volts away from ground.The point is it won’t switch the injectors to ground unless pre-conditions are met.
Those are:
1: it see’s a signal indicating that the fuel pump is running during cranking
2: it see a signal from the oil pressure switch to indicate pressure
Page 6-101 if you have the Chiltons manual
Page 10-20 if you have the Haynes manual
For the pin outs to test.
You are checking for a ground issue you may or may not have but the operation of essential items to test has not been done.
Put your scope on the pins indicated and tell us what you find.
Think there is a good chance the injector is working. What is dosn't rule out is a blockage in the fuel rails.
I have the 1991 Camaro Service manual.The point is it won’t switch the injectors to ground unless pre-conditions are met.
Those are:
I agree, anything the ECU needs to be present to fire the injectors should be checked for. My point was about how it inhibits injection activation? Assuming something is missing, electronically speaking it seems strange for there to be any waveform at the injectors at all if they aren't supposed to be firing. That was all.The point is it won’t switch the injectors to ground unless pre-conditions are met.
Those are:
Both my circuit diagrams and the one I found on-line show the oil pressure switch and concur on the pins they use.
Yes, that's my thought pattern too. I am happy the electrics are looking good now. Earth improvements to the ECU has given a better switch to the Injector.Rockauto list an oil pressure sender for the car.
Located next to the oil filter?
Pin e13 / grey is correct. What are pins B1 and C16 doing?
But this looking good to me, so we are back to fuel delivery. You really need to verify fuel pressure at the rail and an injectors ability to deliver. If fuel pressure is ok I would think it’s worth throwing money at the regulator.
