AmericanThunder
Super Moderator
They are only around £40 from rock auto, so perhaps worth just slinging a new one in there and any other seals I may need.
That’s the approach I would take.
What's your thinking?Before you spend money.......
Do you have access to a fuel pump you could hot wire in to a container of fuel? Just a thought....
Oh yes. Would be nice to get a pressure reading, but I have nothing in that thread. Removed the schrader valve, so anyone know what that thread is so I can purchase an adapter. Thought it may be. AN- thread, my pressure guage I beleive is AN- thread which is finer than the thread on the Camaro.Good on will for popping round so an order to rockauto with mybe a magnet lol
You'd have to throw it over the border as you are on lockdown.shame you not nearer as i proberly have an adaptor to fit ,
Looks like the diaphram comes with the spring bit.Can you buy the regulator or just the diaphram
You're welcome DanHad the day off yesterday. Didn't get much time on the Camaro as had other things to do, and other things to do today.
Will popped round(thanks Will) and we took many parts off,. Looked at the fuel rail.
Cleaned things up.
Took out a couple of injectors. I blew threw them while Will attached the power. Stale fuel came out. Which means fresh fuel was never getting to them. Fresh fuel would come out the Schrader valve.
So what's in between? The fuel pressure regulator. A common fault is the diaphram going. The diaphram is good. Looking inside there is some rusty bits inside the regulator around the thin pin bit. Probably caused by the hole in the vacuum pipe. Due to the rust I'm treating the regulator as suspect. So disabled the regulator as gonna get a new one. Either something bad in the regulator or not enough pressure pushing on it.
Pop things back together and check for leaks before putting the intake on.
That would be great thanks it would be good to confirm the fuel pump is doing what it should. If pressure is bad I will order a new pump too.Dan i have a fuel system pressure test kit it has a selection of adaptors in it you are welcome to borrow it
Locking rings are not in rock auto which is why I'm going to have to make something that will work as well.
