It has one on the dash, yes.This may help. It’s a V8 Tahoe but the circuit design and even the colours of wires used is identical.
I’m assuming the car has an oil pressure gauge?
I have a Henry.The fuel regulator needs to hold a vacuum, see post 53. If you have a vacuum tester (like a mighty vac) you could test it.
If they go open circuit it thinks its -40 degc or similar and dumps on shed loads of fuel, don't know what happens if it goes short circuit. Certainly something to check. I'm not getting any fuel at all in the cylinders.What readings are there for the fuel injection temp sensor, mine went bad and pretty much filled the inlet with fuel,,,worth a check
Hmmmm, Henry wasn’t quite what I had in mind.I have a Henry.
Found a post where you replaced 3 sensors on the Fiero, https://www.solent-renegades.co.uk/...o-your-vehicle-today.12964/page-35#post-62868The IAT went bad on the Fiero. It didn’t fill the intake with fuel but I’m struggling to remember what the symptoms were. Sure it is documented on here somewhere?
This is a mighty vac!
Very nice for an unloved car, they cant have enjoyed driving it for that low milage, seems a waste to me. They seem confused of what it is "I’ve found the fix for Sarah’s Camaro...
CHEVROLET CAMARO RS 2.8 MANUAL, ONLY 4700 GENUINE MILES | eBay
Find many great new & used options and get the best deals for CHEVROLET CAMARO RS 2.8 MANUAL, ONLY 4700 GENUINE MILES at the best online prices at eBay! Free delivery for many products!www.ebay.co.uk
The value in the diaphram dosn't appear to move, but I guess it wouldn't have to move much to function, even less than 1mm may be enough travel for operation.My understanding is that the rubber diaphragm controls the operation of a valve located under the circular disk. The fuel flow enters under the disk, passes through the valve and exits to the fuel rail. The amount of vacuum determines how high the valve is lifted and therefore how much fuel flows. The picture you posted shows that quite nicely I thought.
But, I have never had one apart so feel free to correct me.
