Cleaned up the bell housing and started cleaning the gearbox last weekend.
The input shaft of the box did have quite a bit of play in it. This was down to a worn shim not pressing enough on the bearing.
I have a friend who has a friend that specialises in gear boxes. So kept trying to contact him during the week, leaving messages.
The block went to Banda to have 4 thou taken out of the bores. The pistons needed a 3.903" bore, stock was 3.898", it had been honed so was 3.899".
Got a phone call Monday to day the block was ready. So got a quote to see how much they could install the rotating assemble for. £60 for the hone and £140 for the rotating assembly installation. So took all the bits, like crank, rings, pins, rods and pistons down there first thing Tuesday.
It got to Wednesday, and getting short of time about getting the gear box sorted, still no call back from that chap. so took it to a place in Fareham, gave them the bearing and seal too, may as well put in a fresh bearing even though the old felt good. They are gearbox specialists, called Briggs.
That evening I got a call back from the other gearbox guy, but said I have taken it somewhere else now.
